where do i check the lhm fluid on my c5 and what does it dO?
gazzas c5
Unread post by gazzas c5 »
Hi folks where is the LHM fluid reservior?as i need to check it as my front suspension seems to be sinking ,pretty annoying me now
cheers
CITROEN C5 2.0 HDI VTR 04 REG
CITROEN C5 2.0 16V EXCLUSIVE 53 REG
CITROEN C5 2.0 HDI EXCLUSIVE 52 REG
CITROEN C5 2.2 HDI EXCLUSIVE AUTOMATIC 54 REG FACELIFT MODEL
CITROEN C5 1.6 HDI VTR 05 REG FACELIFT MODEL
wright
Unread post by wright »
c5 takes lds fluid, the reservoir is under the cover on the left side of the engine bay
02 C5 2.0 hdi 110
jmd
Unread post by jmd »
And check, but I think the level must be checked with the suspension lowered fully. The tank is marked to where the oil level should be, but it's difficult to see the marks which are situated at the rear (bulkhead side) of the tank. The L.D.S Fluid just concerns your steering & suspension. Brakes are on a separate circuit and takes DOT 4 brake fluid.
x 5688
P4112313 by myglaren, on Flickr
P4112314 by myglaren, on Flickr
The LDS should just cover the bottom or the filler 'strainer' with the car on it's lowest setting
x 94
Unread post by citronut »
and you must NOT put LHM in as it dont mix with LDS,
regards malcolm
boristhespie
x 4
Unread post by boristhespie »
The garage today said this resevoir was filled with lhm.
Plus they didn't lower when they checked level.
C'est pas possible!
x 1955
Then they don't know what they're talking about.
If it's the same garage that worked on your car before then I strongly suspect that they didn't replace the undertray clips properly either.
boristhespie
x 4
Seems likenit. I have exhausted all the garages within a 20 mile radius of here and it seems going by what you guys say that none of them really know what they are talking about in relation to my car/s.
Most shockingly the 75 quid an hour dealers know nexr to nothing. All sort problems through expensive trial and error.
And yes i noticed the undertray held up with ziptie last time oil changed. So clearly had broken tray.
But what can yoy do when you ain mechanicallynmided nor have a drive on which to take things apart?
C'est pas possible!
