V6 Heater Pipes and matrix
Ozzie Kuma
Unread post by Ozzie Kuma »
Thanks,...I need one but it depends on the $$s whether I want one or not , $50-ish + shipping sound good, & I'm in no hurry,.. let me know if you need $s or if I can do anything to assist.
98 Xantia V6 MK2
95 Xantia VSX
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I'm on a modest hurry simply because I always have a zillion things on the go and hate stuff which doesn't work as planned.
The fellow you spoke to about R&R on the dash for this job, also wants some cores himself - there's a Xsara to do, and I think a Blingo as well.
Since you're with the wallopers, and in IT - sure you can help - replace the present "zero" for my demerits with a negative number so I have a few transgressions up my sleeve... :lol:
lexi
x 134
Unread post by lexi »
What you say about the Valeo matrix could be right Jim. But the Valeo matrix is used on Rangerovers as well...........they are pish :lol:
All the Jap cars I have had aint ever had a matrix go........and far better air con too. s**t parts ?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
addo
x 95
Vollies are Valeo too - guess what? Many '90s Volvos here, have bypassed heaters...
Ozzie Kuma
OK, I have researched the hell out of changing the heater matrix / dash removal.. It's very cold here @ the mo, so I am keen to get started,.. all I need now is the matrix but that is proving a bit of an issue.
What are the logistics around buying one in UK & having it shipped? I have never done anything like that before.
98 Xantia V6 MK2
95 Xantia VSX
x 8181
Ozzie Kuma wrote:It's very cold here @ the mo
Ozzie, what do you call cold these days? I know in Darwin 17 degrees in the middle of the dry season (now ish..) was bloody freezing :lol: :lol: :lol: :lol:
17 degrees here is really pretty toasty....
Seriously, plenty more matrix fitting advice is available...
Are you and Addo not doing group buy of matrices then?
addo
x 95
Jim, I'm not sure what he's doing; my landed cost was beyond his indicated spending preferences. I will have four of the rotters on Tuesday arvo. Series or parallel connection best? :lol:
Ozzie Kuma
Jim,.. cold is relative, as I just posted on addo's "disappointed" , drive fast enough & you don't feel it.
addo, I always wanted a matrix,.. I have posted things here & on frogs but we seem to have got our wires x-ed,.. last I thought I said was do you want some $$$s, & yesterday I thought I sent a "pm" ( that is a private message isn't it?) on this or frogs,..
anyway, I want one assuming it is not $1000.
correction,... "Ripper day out" not "disappointed".
98 Xantia V6 MK2
95 Xantia VSX
addo
x 95
Got to say, I haven't received any PMs from you here, and haven't read or participated in Aussief***wits since last Spring.
Anyhow, if you desire, you can have one Wednesday (assuming they arrive undamaged :shock: ) - it will come with a copy of the sales invoice so you know how much was paid. I think you'll be pleasantly satisfied with the item and its cost.
Ozzie Kuma
very much appreciated,.. does it include installation ?
Poor attempt @ humour,.. on that . I assume you are doing one on a Xantia, if you want a hand, please let me know,.. I would love to assist in repayment & learn what I am in for.
98 Xantia V6 MK2
95 Xantia VSX
addo
x 95
I don't know when I'll be personally doing mine - the dash is going to be replaced with an unpunctured one presently occupying my kitchen floor... Besides, the firewall soundproofing needs renewal or repair and that's $1300 I don't have up my sleeve at present.
Ozzie Kuma
ok,..offer still stands,.. I await to here from you,.. let me know how much please , I don't leave much between pays to play with either. Thanks again.
98 Xantia V6 MK2
95 Xantia VSX
lexi
x 134
There is a short cut/trick to doing the Range Rover ones. Anyone done similar on a Xantia? Like angle grinder to the bulkhead and then weld the bit back in :lol:
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
addo
x 95
Lexi, it more or less slides up and out - you might get away with removing the windscreen and cutting a porthole in the dash top? :shock:
Our OP now has a matrix, also I disconnected the bulkhead pipes for him as having done a couple of hose repairs I have a feel for the "push clip/wiggle-and-pull coupling" process required.
Ozzie Kuma
. thanks Adam...it's those little tricks that will save me hours & much frustration in the long run.
I will not get it started for a while yet unfortunately (re-broke some ribs!) so I am researching the hell out of all the little tricks.
98 Xantia V6 MK2
95 Xantia VSX
