Tomorrow should be an ideal day for V6'ing. Surely everyone will be in full Royal Wedding mode?
Go to a car boot, you never know what you might stumble across
There is an extra relay under the steering column (see earlier posts), that the wires had come loose on, and I must have connected them back up the wrong way.CitroJim wrote:Which of the big fuses did you blow and how?
If it was B then the surge through the ignition switch may have damaged it.
Checked the fuses and no power there. Have not bridged the connectors yet as not sure of the brown connector. Is it this one below??CitroJim wrote: You can test this by disconnecting the brown connector at the ignition switch and linking the pins together with suitable heavy wire. If everything them works then it's the switch.
Also, check you have 12V present (with the ignition on) on fuses F5 and F21 in the cabin fuse box. Again, check again when trying to motor the seats.
Hi Paul.citroenxm wrote:Are wires 4 and 5 connected to the ignition switch???? If so then they need connecting to the brown plug.....
Paul
