Xantia HDi issue
Chris570
- x 36
Xantia HDi issue
yesterday when starting the car from warmish (had been off for 2 hours) the car was idling very lumpily. The best way i can think of describing this is as if it was running on 3 and a half cylinders. I suspect injector problem as when warmed up (30 seconds of driving) all was well. this is what i get when i plug it up to the lexia when its stone cold. What do we think as to me injector 3 looks out (although maybe not far enough) there are no fault codes stored other than an intermittent EGR one.
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
KevMayer
Chris570
- x 36
- x 8462
Chris570
- x 36
CitroJim wrote:Bloody hell Chris, either you have gone to Scotland and back today or she's really drinking it - I thought you said her tank was brim-full last evening?Chris570 wrote:well, i've just put it in![]()
had done 60 miles since the fill up so i managed to just squeeze the 500ml in the tank (as opposed to the diesel which would take a barrel by now)
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
KevMayer
I usually put the Diesel Magic in when my fuel level is low, then it's more concentrated to give a more intense clean.
Some pour it directly into the fuel filter housing.
I'm not sure it will give such good performance if it's dilluted by a tank full of diesel
Cheers, Kev
wright
Chris570
- x 36
well after doing 300 miles yesterday i can confirm that the lumpiness isnt there (i'm still reserving judgement though till its done more miles)
there is still a very light knock at tick over sometimes though....
it was knocking the other day at tick over but a bit worse than it was yesterday...
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
