hey gang which is the correct way up for a thermostat in a dq10 hdi, should the spring side be the highest poin or should it be the nipple part?
i have been putting the nipple part facing up, thats the way i found the old thermostat too.
but when i replaced the old thermostat with the new thermostat, the car actually overheated more!
83 is the rnumber on both thermostats if that holds any relevance.
I will take photos of it and post here, once i find my camera cable!!
here is a pic to how i found the old thermostat, is this the correct way up:
https://picasaweb.google.com/1096236004 ... 4877792770
by the waym, the new thermostat looks different, but it fits fine, it still has 83 written on it, but it just looks a little different, should they be absolutely identical?
thanks
ed
right way up for a thermostat?
eurotrotter
- x 1484
eurotrotter
it was right so, normal for a hdi is 78-80 degrees, from my understanding and i have done a lot of research on this, not being smart or anything.RichardW wrote:Nipple up, spring down is the right way round. If it's overheating, check the stat in a pan of water. Is it really overheating though? Normal running temp for an HDi is 90°C - rising to 100°C before the fans cut in....
but the new thermostat cases the car to run at 90 degrees!
i removed teh thermostat a couple of days out, just to see what would happen drove ont eh autobahn at 80mph for an hour and the temp went from 80degrees, to 60 degrees- lowest point on temp gauge!
and stayed there, until i got in the city, and as soon as i went back on the open road it went down in temp very quiclly and would go to 60 degrees within 4 minutes say!
- x 1484
No, wrong I'm afraideurotrotter wrote:it was right so, normal for a hdi is 78-80 degrees, from my understanding and i have done a lot of research on this, not being smart or anything.
eurotrotter
- x 1484
411514
- (Donor 2017)
- x 40
