Diesel leak
fridgedoc
Diesel leak
Unread post by fridgedoc »
Hi Guys
What is going on!!!!!!!!!!!!
I have just sorted one leak (on a sphere) now I've got another this time on the fuel filter, the car did not start on the initial turnover, it normally did and Mrs fridgedoc took 3 or 4 attempts before it started, so bonnet up, tried to pressurise system with bulb, could smell diesel, found leak on side of filter, this is on the left hand side looking from front of car, the filter case is all black apart from this bit that is white'ish, never noticed before and it's around this part that it is leaking, asking first before I start pulling things apart, just wondering if a cover of some sorts was missing? or is that just wishful thinking : )
Many thanks in advance
Bonne Chance
Stephen
LHD Xantia 1994 (deceased)
LHD Xantia 1995 Berline
KennyW
x 164
Unread post by KennyW »
Bon Jour Stephen,
Is that the water drain off screw thats mention in the BOL. It may be loose and only requires tightening.
Kenny
C3 1.4 petrol (SWMBO)
fridgedoc
Thanks Kenny.........if only, the water drain-off is at the front and is tight
Many thanks for your reply
Bonne Chance
Stephen
Chris570
x 36
Unread post by Chris570 »
its the valve on the back that diverts some fuel through the warmer underneath the filter. its a common leak, i'm not sure if you can still get new seals but its all nice and easy to take apart and put back together :)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
KennyW
x 164
Stephen,
Here is a copy of a diagram from the french Xantia book, if you can identify the leak part from it great.
Kenny
fridgedoc
Hi Kenny
Sorry, been trying to upload photo of part, and will it upload, will it heck, but from your diagram it looks like it is No. 10.
Going to try and up load this photo again
Hey i cannot take the credit for up-loading this picture, big thanks to Steve "myglaren"
Bonne Chance
Stephen
KennyW
x 164
Hi Stephen,
I thought it was from your description. Looking at the diagram, there appears to be a seal or 2. Do you think they are responsible.
Kenny
x 8322
That's the fuel thermostat. It sends the fuel through a labyrinth in the thermostat housing when cold. It's a pretty common place for the housing to leak from.
There's two O rings on it. They're not available as replacements and the thermostat is hard to dismantle as it's held in place by a star clip.
Normal method of repair is to replace the whole housing or to remove the thermostat and seal the hole with a plug of chemical metal. If you do the latter the area must be spotlessly clean and free of every last trace of diesel or the repair will fail.
fridgedoc
Hi Kenny
I'm pretty sure they are responsible or in this case ph°°ked
Hi Jim
I'm going to give it a go, replacing the O rings if possible if not then block it off or if I can get one replace the housing
Does it ever end !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ps. it is flash crashing that is stoping me uploading pic's
Love to all and thanks for your input
Bonne Chance
Stephen
fridgedoc
Hi Guys
my own uploaded photo
not that it matters as we know what the problem is.
I was right it was "flash" that was stopping me uploading pictures
Bonne Chance
Stephen
