having an intermittant problem with speed control fault with cruise control.have been led to believe that it is a fault with either switches on clutch or brake pedals can someone tel me where they are situated
thanks in advance
c5 speed control faulty
AndersDK
In the peddle box ...
bend down and feel how your spine is still present in your body
You are lucky you have a RHD car as then the brake stopligtht switch is located in the passenger footwell - connected to your pedal by an axle tube.
On mauals you will also have a switch on the clutch pedal - in the drivers footwell.
Commonly it is the brake stoplight switch messing up.
Accompanied by stopligths failure.
Anders (DK) - '90 BX16Image
mavandy
I had a nosey under the drivers side for the clutch and could not see any switches i also took the instruments out to see behind and after i moved a piece of foam all i could see is some welded iron work possibly for the pedals i had a look in the haynes manual and it says something about removing the wiper mech to remove the clutch pedal.
CITROEN C5 2.0 16v VTR 56 reg
CITROEN XSARA 1.4 8v FORTE 2001 X REG
AndersDK
- x 1496
mavandy
falling-out-with-my-car
- x 25
Re: c5 speed control faulty
ive got the same issue with my mk2 the clutch has gone so I have a gut feeling it is the clutch switch being as the pedal is almost on the floor.
