Wheel knocking
411514
(Donor 2017)
x 40
Wheel knocking
Unread post by 411514 »
Ive just changed the drop links on the c5 for the mot, all well, however when i went to drive it there is a loud knocking noise when the wheels turn. As speed increases the noise becomes more frequent its definitely the drive rather than engine, and im guessing its driveshaft related but i havnt a clue what or why, i didnt touch the driveshafts only the droplinks, if anyone has any ideas as to where to start any suggestions appreciated, its a 2003 2.0 hdi vtr if that helps, cheers sam
x 1476
Check you've tightened the wheel nuts up properly...been there done that!
x 94
Unread post by citronut »
you have fitted the drop links the right way round in there mountting eye's????,
regards malcolm
x 1911
When I changed the driveshaft on my C5 I had to disconnect the bottom ball joint. As a result the hub assembly could swing through more than its normal articulation and when I put it back together there was a knocking sound at wheel speed when I reversed.
It turned out to be the bracket with a slot in that guides the handbrake cable had bent slightly and as a result was catching on the wheel balance weights on the inside rim.
A bit of judicious "tweeking" with a big screwdriver cured the fault.
wright
Unread post by wright »
did you swap front and back wheels, a buckled wheel from the back might clip something on the front
02 C5 2.0 hdi 110
411514
(Donor 2017)
x 40
thanks for the input guys, you were spot on Paul-R, it was the handbrake hose guide catching the wheel weight on each rev so thanks very much for the tip, glad it wasnt anything more serious, cheers sam
