Xantia oil leak
froggy
(Donor 2026)
x 4
Xantia oil leak
Unread post by froggy »
Hi, I have got a nasty oil leak, coming from the rocker gasket. About two oil changes ago , I started using "Millers Oils" , 10w - 40 , instead of "Mobil 1" . Could this be the cause of the oil leak ? Should I have stuck to "Mobil 1 " ?
Do I need to torque wrench the rocker cover back on ?
Cheers Terry .
x 1240
Unread post by Peter.N. »
Hi Terry
I doubt that changing the type of oil would cause a leak, I think it would have happened anyway. You don't say what engine you have but taking the rocker cover off shouldn't be to difficult, I don't know if there is a specified torque for the bolts but just tighten them sensibly, the size of the bolts should give you a clue to how tight they should be.
Xaccers
x 185
Unread post by Xaccers »
The gasket goes hard after a few years, might be time to buy a new one.
DIY sphere tool
Xantidote
x 5
Unread post by Xantidote »
As Xac says, the rubber gaskets do become harder as the years go by.
If your engine has a breather hose coming from the rocker box/cam cover, it could be that it's splitting at the end. I've had this happen on a TD engine, and the split occurred on the underside, where it was difficult to see
Martin
x 94
Unread post by citronut »
as Xac says fit a new gasket, but you will be best checking into the tightenig torque,
as many of these cam covers are case alloy and if you over do it you can crack them,
regards malcolm
VertVega
x 13
Unread post by VertVega »
If it is a 16V (1.8 or 2.0) then camshaft cover nuts/bolts tightening torque is 10 Nm.
