Do I need a special tool?
atr
x 6
Unread post by atr »
Hi
I've purchased the rubber pipe & pad for the strut hydraulic fluid return . it is attached to the strut with a metal clamp. I think that it will be possible to remove the clamp, but since the new pipe comes with a clamp, I would like to ask if there is a need for a special tool to install the clamp or it can be done with pliers and a screwdriver? waiting for your advises.
Thanx.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I suggest flush ground end-cutters; if you are unsure what these are, look up the Google Images - easy to mimic with an old set of pincers (nippers) ground flush on the face.
HDI
x 7
Unread post by HDI »
Oetiker pliers.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
x 1902
HDI wrote:Oetiker pliers.
I thought he was a Dr who made cake mixes? :)
x 94
Unread post by citronut »
carpenters pinchers are ideal for this job, or it is possible the use a large pair of electrical side cutters,
regards malcolm
