Hi all,
I am about to purchase a Hymer motorhome fitted with a Peugoet 2.5 Turbo Diesel engine.
Am I correct in that it is a CX engine that is fitted?
Is there anything I should be checking?
Hymer
- x 1240
Depends on the year but its quite likely. Good engine those unless you get one with a pourous block as I was unfortunate enough to, I think it only affects the turbo's but results in frequent failure of the head gasket - still a nice engine though.
I have just had second thought about that, the CX engine was as far as I know only used by Citroen, the Peugeot 2.5 engine is different and was used in the Granada apart from the 504. That was the XD series of engines.
