![Cool 8-)](./images/smilies/icon_cool.gif)
Sounds as though its going well and not drinking too much fuel either.
What are your plans for it, or bits that need doing?
Moderators: RichardW, myglaren
Needs a breather pipe and spheres doing ASAP, NSF headlight and OSF indicator lens need replacing before the MOT runs out. Clutch pedal's on the high side, so I'd imagine that will need doing sometime later this year, though I'm a pretty gentle driver and there's no hint of any slip, it's just high on the pedal.Citroenmad wrote: What are your plans for it, or bits that need doing?
Richard....ive thought about that beforeDickieG wrote:Bearing the above in mind I'll have to see how DS Pallas wheel trims look on a Xantia
I'll check them soon but they both use 15" wheels so possible but DS Pallas wheel trims in good condition are generally around the £60 mark each, so as in everything in the DS world costs generally work around £200 mark whatever you dovince wrote:Richard....ive thought about that beforeDickieG wrote:Bearing the above in mind I'll have to see how DS Pallas wheel trims look on a XantiaI presumed the clips would be different and wouldnt accept a normal steel? Am i wrong?
I want some
red_dwarfers wrote:Brilliant!
Whats that it says on the side?
