Hi,
Last Friday evening after driving about 200 miles and with 30 miles to go my Xantia 2.0 16V (W reg) suddenly overheated. I stopped immediately the red light came on and found the top radiator hose had blown off. After about an hour and a half the hose was reattached and the radiator filled. Cranking the engine produced a fountain from the radiator filler at which point the car was declared dead and loaded onto a tow truck.
I now have the head off and was surprised/concerned that the failure is not obvious. I was expecting to see a clear point of failure or physical damage on the gasket but can't.
Is this normal for a HGF and other than having the head pressure tested and checked for flatness should I be looking for anything else?
Prior to the failure there had been no history of overheating and no symptoms of HGF (such as mixing of oil and water).
Thanks,
Martin.
Sudden head gasket failure
addo
- Sara Watson's Stalker
- x 95
martinwiseman2000
No evidence of corrosion at all.addo wrote:Very odd! Is there much corrosion to the water passages in its head?
Looks ok, but I'll test it this evening.addo wrote:How does the thermostat look?
I was wondering about that, as it's the only other place a fault could lie. Would it be obvious it would it only be the sort of thing you could find with a pressure test?addo wrote:The other weird one (very "old school" in terms of modern engines) is a split bore.
Thanks,
Martin.
citroenxm
- Fallen Hero
- x 70
Sounds though, more like that fact the gasket hasn't failed, but due to lack of water the head has got too hot... and warped the cylinder head instead..
When you refilled at the side of the road did the car actually start and run?
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 94
MikeT
- x 232
- x 1240
martinwiseman2000
No, it coughed and spluttered, sounding as if was only firing on one or 2 cylinders. I stopped cranking before it actually ran.citroenxm wrote:When you refilled at the side of the road did the car actually start and run?
When I took it apart there was water in the middle two cylinders. Assuming this was the case when I was cranking it the damp spark plugs would have prevented them from firing. I assume the fault would have initially occurred on one cylinder and that the overheating warped the head allowing a second cylinder to leak.
Martin.
addo
- x 95
martinwiseman2000
