Hydraflush / sphere changing. Freeing up rear suspension.
rmunns
x 9
Unread post by rmunns »
Year 2000 Xantia Hdi90 saloon.
Last weekend I drained the LHM, cleaned tank and filters and re-filled with Total hydraflush. No problems, it went well.
I now want to replace all three rear spheres (car is not hydractive / activa).
Are there any drawbacks to doing this while hydraflush is in?
If it's OK to do this are there any special precautions I should take?
Regarding the rear suspension; I want to be sure I have freed up the dog bone and the coupling rod that comes from it. But I'm not totally sure how best to do this withoput stripping anything down.
x 94
Unread post by citronut »
there should be no problems fitting new sphere's with hydraflush in the system,
and the only way to free off the H/C linkage/turrets is remove them from the car,
as they realy need to be floppy loose,
regards malcolm
rmunns
x 9
Thanks Malcolm, I'll give it a go.
