Which wheels are these?
vince
x 13
Unread post by vince »
Thsi is on ebay at the moment. Im not thinking of buying it, but i do think the Xantia suits slightly bigger wheels....what are these? Picasso?
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Redrill your car for five stud, like an XM. Then you can run C6 wheels. :twisted:
I've got chavvy 17×7s on the 605; it came like that and really hurts the insurance for no perceptible gain... Can't wait to put some OEM wheels on.
Citroenmad
x 110
Unread post by Citroenmad »
They are 16" steels with trims from a C4 Picasso, yep.
Tyre size on those should be 215.55.16 but they look slightly lower porfile perhaps.
Im trying to find a set of 16" Citroen wheel trims to cover up the steels ill be getting winter tyres for, but so far cant find any for less than £70.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Toby_HDi
x 3
Unread post by Toby_HDi »
I do wonder if the Activa would look good on Coupé rims. Might try it sometime.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Citroenmad
x 110
Plenty of nice C5 wheels, both 15" and 16", available. They bolt straight on.
Toby, are there different sizes of the same style Coupe wheels?
I saw a 406 saloon (taxi actually) wearing Coupe wheels, they seemed to sit very nicely in the arches, it looked good.
03 Seat Arosa 1.0S
robert_e_smart
x 14
Unread post by robert_e_smart »
No need. C4 VTR Rims are 4 stud, and more common.
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
Toby_HDi
x 3
Chris, there are two different sizes.
205/50R15 and 215/55R16
Also there were 4 different wheel designs but I was talking about the 'Starfish' design which mine has. Only issue may be offsets as the wheels need to clear the Brembo calipers fitted to the V6s. Not entirely sure of the offsets on the Coupe or the Activa are really.
Toby
Previous:
addo
x 95
D9 406 Coupé: 12-15 offset (latter only on 15" steels)
D9 406 sedan: 18-20 offset (basically dependant on 6J or 6½J rim width)
Activa Series II: 15 offset (Le Castellet wheel is 8mm, being a 5½J rim)
Kowalski
Unread post by Kowalski »
Citroenmad wrote:They are 16" steels with trims from a C4 Picasso, yep.
Im trying to find a set of 16" Citroën wheel trims to cover up the steels ill be getting winter tyres for, but so far cant find any for less than £70.
215/55/16 will a larger radius than the standard tyres that a Xantia came with are wider than the standard Xantia tyre too. The biggest standard tyre on the Xantia would appear to be 205/60/15 so 205/55/16 would be closer but it's radius is bigger too!
215/50/16 is very close for rolling radius but again, it's wider and may rub when you're cornering with the car fully loaded!
Trainman
(Donor 2018)
x 43
Unread post by Trainman »
addo wrote:Redrill your car for five stud, like an XM. Then you can run C6 wheels. :twisted:
245x45x18 I think you may have to flare the wheel arches a bit :lol:
Steve
http://c6owners.org/index.php
