So long and thanks for the help
HST
Unread post by HST »
citronut wrote:i dont find PSA diesel's noise'y if the cam and pump timming is running as its ment to, and the enging is not worn out,
mine does not sound like a tractor like other manfacturers diesel's of the same age,
regards malcolm
It was only at idle that mine was particularly noisy, on the go it was fine. Even a few revs above idle it quietened down.
Citroenmad
x 110
Unread post by Citroenmad »
The HDis are quite a lot more refined than the XUDs, quieter at idle especially. They also have a wider spread of power which makes them nicer to drive and require fewer gear changes.
PSA have been amongst the top manufacturers for diesel engines for years now.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 1240
Unread post by Peter.N. »
Still not as nice as the 2.1 though :D
Citroenmad
x 110
Peter.N. wrote:Still not as nice as the 2.1 though :D
Hmmm :lol:
I think the 2.0HDi 8v and 2.1TD are very good engines, apart from the HDI having more power more of the time they do drive fairly similar.
The 2.0 16v HDi is a lot better to drive.
03 Seat Arosa 1.0S
x 1240
The 2.1 is smoother and more progressive from 1000 - 1500 rpm, the power all comes at once on the Hdi and not as smoothly.
