Yes looks OK.
The difference is the big O in the end of the release arm where the end of the cable fits. The 'other' type has a big H bracket around it. If the release arm looks the same as yours then it is, there's only two types and they look quite different.
mi16 gearbox on diesel xud
spider
- x 77
- x 8263
spider
- x 77
That's a thoughtCitroJim wrote:I believe though, that the release arms and bracketry can be swapped between 'boxes; the castings being the same and all the tapped bosses and etc. will be there to fit what you need.
The 'box is the picture is certainly nice and oil-tight
You are probably quite right too. I was thinking it would be best to do a like for like, but I guess you can swap the arm / fork assembly too.
As jackel will be using the correct clutch for the release setup, should be fine.
Andy.
jackel
jackel
spider
- x 77
- x 8263
spider
- x 77
The 'effect' of that usually is to give you a 'shorter' cable as far as I can tell.
I thought about a worn out clutch causing it but then again that's been looked at while the box was off.
I do remember something like this on a 205, cannot remember but they kept 'adjusting' it till it went through the fingers
Andy.
spider
- x 77
Yes, a piece of rubber each side of the arm, the cable has the washer etc built into it as you can see. I think a plastic spacer (the size of the hole in the arm) too should be there.
The manual cable looks almost the same but instead of that rivet at the end it has a thread.
Andy.
jgra1
- (Donor 2021)
- x 36
I cant see any pics here at work, but this may help
http://2.bp.blogspot.com/_2fj8MH_LeQ0/T ... 2Bcabl.jpg
should show a TD auto adjust and manual adjust cable side by side.
John
John
