I have a 2000 Xantia 110 hdi with key plip problems sometimes it works sometimes it doesnt I think I read on this forum that you can replace the buttons on the plip if thats right where can I get them thanks
allan
key plip
citroenxm
- Fallen Hero
- x 70
The PLIP buttons are surface mount stupidly! And the solder can and does break quite easilly, its soldered onto the board in the 4 corners, with NO rear support to stop it breaking off...
Ive re soldered a few with a very fine iorn! Even applying a little bit more solder then previously, with sucess... You may find this is your problem.
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citroenxm
- Fallen Hero
- x 70
dnsey
- x 19
- x 8089
Re: key plip
It'll be the switches themselves Allan. They are used all over the place in modern electronics and wherever they're found you can almost guarantee to find they become troublesome after a few years use. They're little membrane switches, not unlike those used on a keypad.allanmc wrote: the solder looks sound
Replacements are freely available and I expect Maplin will stock something similar and suitable.
- x 94
- x 94
i3
citroenxm
- Fallen Hero
- x 70
Mk.1 Xantia PLIPs are a doddle... Any other Mk.1 Xantia PLIP IR type, can be programmed to a Mk1 car... So get one - making SURE its a Xantia one from Ebay...
Mk1 PLIPs were still available from the dealer a couple of years ago.
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
