My car engine stop light comes on and over heats after about 5 miles driving. i have had the water pump changed but the problem still persists.
Can someone please give me some advice
HELP!!!! my xsara lx is overheating
afil1
- x 1955
Was the system bled of air properly after the new pump was fitted?
Why was the pump changed originally? Were the engine and radiator back flushed?
Are you losing any water? Is there any "mayonnaise" in the rocker cover when you remove the oil filler cap? There's a possibility that the head gasket or cylinder head itself might be faulty.
carr3626
carr3626
Sid_the_Squid
Thermostat that won't open?
no idea what this is like on the Xsara, but would have though an easy and cheap item to change.
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
Past Citroens
'97 Xantia 1.9D sx
- x 94
carr3626
wotwot
- (Donor 2021)
- x 4
- x 94
