jgra1 blog
- x 5675
jgra1
- (Donor 2021)
- x 36
- x 8423
John, that's terrible
How on earth can it possibly be objected to. You can't see it until you're practically on top of it..
These council people must have very sad existences. I mean, your place is not exactly accessible and visible is it? If you'd have built your garage on the steps of Nelson's column in Trafalgar Square then I could see where they were coming from but where it is, the only living things that are ever going to see it anre a few birds.. Maybe a gang of ducks on the lake complained?
Take a tip from the newspaper article and strap an outboard on it and claim it's a houseboat...
jgra1
- (Donor 2021)
- x 36
the (very distant) neighbour(s) probably started things rolling
so 3 different issues really, a complex situation.. but I really have a problem going down the planning permission route, as I thin kthey will ask me to take it down anyway and built it with more sympathy.. never mind the costs..
so adding some wheels may just be a great way out of this..
If I could just get spheres on each corner it would really help things along
jgra1
- (Donor 2021)
- x 36
hi all, happy new year etc
been off the forum for a few weeks !
I stopped spannering for some reason about the time the mundano I was working on wouldn't heal itself.. despite a head rebuild, cambelt kit and many many hours of my time.. really got to me
anyway, a nice christmas ended with a week in Malta
interesting place..
I have the usual suspects of jobs waiting, car wise : xant needs hydroflush, possibly 2 spheres, 4 tyres, the new discs fitted in Autumn seem to be causing a grabbing sensation.. clutch cable, still need a wing and could do with a bonnet..
used the xant in the snowfalls, was great not getting grounded like every one else was
coupe, still not finished LPG'ing it
also needs tyres and tracking and the ever present steering fluid leak..
the shed is now officially attempting to get itself permission to remain where it is.. wont know much more for a week or two.
also, the doc has finally told me to take Blood pressure tablets .. still dont want to... and i now have an irregular heart
I was already becoming a hypercondriact before all of this
- x 8423
Great to see you back John
Hope the shed obtains its permission. I don't know why but only the otehr day I was wondering how things were on the shed front...
May all your jobs get sorted in the coming week. What we need is a bit of spring-like weather...
Keep an eye on the old blood pressure!
MikeT
- x 232
jgra1
- (Donor 2021)
- x 36
jgra1
- (Donor 2021)
- x 36
well the nurse said my trace looked normal
anyway, finally got around to changing the xant TD clutch cable today.. a pig job really.. clutch clip took about an hour, more than usual and this is with me removing the pedal ... it was a long time since I last did one..
http://2.bp.blogspot.com/_2fj8MH_LeQ0/T ... 2Bcabl.jpg
I can say that a manual cable fits an S2 xant.. the old cable wasn't that bad, just a bit gratey on disengage.. the new one is perfectly smooth
but... the clutch is now heavier!
it has to be a routing problem but I can't really see what I have done wrong. the cable does seem to hit the gearbox at a slight angle, it runs down between the selector rods, and traverses the front of the sub frame cross member, before turning up past the turbo and into the bulkhead..
- x 8423
Yes, that's excellent news John
Mind you, old Gerry there does keep a up a good beat...
Strange your clutch is now heavier John
The cable does take a bit of a route though, as I recall, along the front subframe. So long as all bends are easy ones it should be fine...
jgra1
- (Donor 2021)
- x 36
jgra1
- (Donor 2021)
- x 36
Yasi
well. this time a year ago, I had the good fortune to spend a month wondering around Queensland and a bit of New South Wales.. I love extreme weather but i am very glad i went last year not this year
never mind the January floods, I was trying to imagine a 280kph gust of wind, but failed...
http://www.abc.net.au/news/stories/2011 ... 125663.htm
jgra1
- (Donor 2021)
- x 36
good news.. after probably some considerable cost to my Landlords.. it looks like my barn can remain where it is for ever
I have to change all the roofing, and finish the doors, electrics off.. but hopefully now i can get back on with that and get some use from it! I ahve plenty of work to do in it
http://myservice.tandridge.gov.uk/Plann ... wdocs=true
