Sphere Clicks!!
mikep
spheres
Unread post by mikep »
Thanks for all the info it is much appreciated.
mikep
Citroen Xantia auto sx 1996
Old-Guy
x 24
Re: spheres
Unread post by Old-Guy »
mikep wrote:I took it to an independent garage and he said he couldn't change them because you need a special tool.
Translates as "I don't know anything about Citroen hydraulics and I don't want to know!"
The accumulator sphere can be a bit of a pig to undo - the special tools being a big cold chisel and 4lb hammer! Full explanations elsewhere on the forum
KP
x 27
Re: spheres
Unread post by KP »
Sounds like he is the tool LOL
fs2811
Unread post by fs2811 »
A non-Citroen garage will often shy away, and say they need specialist tools! Removing the sphere is like unscrewing an awkward edisson screw lightbult. Replacing the spheres is an easy job to do. You'll lose a little LHM fluid, so check the reservoir when the job's done. A Citroen symbol on the old sphere indicates it's the original part from when the car was manufactured. Sometimes you can find cheap spheres on the internet. If so, it's worth buying the two, plus the four corner spheres while they're cheap, if you're planning to keep the car.
howiedean
Re: spheres
Unread post by howiedean »
mikep wrote:Thanks for all the info it is much appreciated.
Good guide here:
OOOP's I use the cold chisel method to remove tight rear spheres, I'm going to get one of those proper tools.
Regards
Howie
Howie
2006 Fiat Idea Dynamic 1.3 Multijet
2010 Renault Laguna Dynamique tom tom 2.0 DCI 130
C5 VTR 2l 8v HDI Estate 112000 miles gone
Kia Rio 2007 1.5 CRDI 62,000 miles gone
2001 Dodge Durango 4.7 V8 170,000 miles gone
1999 Ford Crown Victoria 4.6 V8 151,000 miles gone
Ref
Unread post by Ref »
Should i order this one?
Chris570
x 36
Unread post by Chris570 »
Do NOT get one of those tools.
They are poor quality metal and not up to the job, they can't grip the sphere properly at all.
total waste of money.
get one from pleadies, they are exactly what the doctor ordered
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Ref wrote:Should i order this one? (Ebay link removed)
I had a bad experience with an aftermarket sphere; since then I am keener to use Citroen ones or regas the existing.
What is the UK dealer price for genuine? P/N 5 451 376
Chris570
x 36
95666763 SPHERE + GASKET 88.70 GBP 106.44 GBP 106.44 GBP
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
Ref
ouch that's quite big difference, if it's 88GBP in UK i won't even bother to ask for it here in sunny finland :(
x 5675
If you are concerned about the quality then they have genuine Citroen spheres for £33
I think that GSF have them for around £20 and they do international deliveries.
Ref
myglaren wrote:If you are concerned about the quality then they have genuine Citroën spheres for £33
yeah i found on their ebay shop but i'm not sure is it genuine or not, i sent them a message anyway asking but no reply yet!
xants in me pants
I am feeling smug and not bouncy
Unread post by xants in me pants »
machine mart chain wrench £7ish and a length of thick steel tube (nicked a bit of my kids swing), sorted! just did front corner spheres, and practiced getting access to accumulator with the same tool, didn't seem like a problem.
wish I had flushed before though as I just read old-guy's point about filling new sphere up with crappy lhm.
edit to add, citroen dealer quote: £200 diy including tool -£65
Deanxm
x 87
Unread post by Deanxm »
Thanks son by Deanxm, on Flickr
:lol:
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
xants in me pants
:lol:
