Having had a peugeot 306 1.9td and now a Citroen Xantia, I have found one of the worst things about the cars are the gearbox's.
Notchy, stiff, and sometimes crunchy, I just think they are simply awful boxes and really let down what is otherwise a good car.
I have to use brute force to get mine into first gear, however if the car is moving forward slighty it goes in as easy as can be.
Also to avoid crunching into reverse I have to select a forward gear then into reverse.
What do you all think, anyone else have the same experiences?
Does anyone else think the BE3 gearbox is rubbish?
andmcit
- x 30
I've driven many BE3 boxed cars and you shouldn't have to almost force the
gearbox into 1st gear. This doesn't sound right at all. Only Xantia alternative
would be the 2.1TD, the later Hdi or Activa with cable selection which are very
light and precise. Or get an Auto?
Could be worn bushes on the rods running onto the gearbox in the selector?
Andrew
Andrew
Xaccers
- x 186
Nope, all mine are fantastic gearboxes, very responsive.
Might be someone's filled yours with the wrong oil.
DIY sphere tool
DIY sphere tool
jgra1
- (Donor 2021)
- x 36
Colski.. they are generally ok I have found.. I must have had 10 of them or more..
your 1st problem sounds more like clutch? the normal BE3 issue is the 3rd gear syncro wearing.. which I am sure is a weakness of the box..
Mine 135K xanita one has become a little notchy on all gears so I am going to check the oil level soon..
mind you
the be3 is the only box I have eve broken in all 30 of my cars. (although that figure is skewed by the amount of PSA;s in there)
I threw part of a pinion out of the side of the box once at 15mph....
mind you
andmcit
- x 30
lexi
- x 134
The last Y REG hdi of mine had a notchy 3rd gear which is a cable stretching. The others have been fine. You probably know that the light oil is a must.
Is is supposed to be a very strong box going by the accounts of members who have stripped them ?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
colski
Oh great! I was hoping you would all say thats totally normal and to just live with it.
Once i'm driving the gears are ok and I don't have any problems with 3rd, its just getting into 1st, and reverse.
Also find changing down to second is quite notchy
When the gearbox oil was changed last year, total 75W-80 was used.
- x 1480
Deanxm
- x 87
lexi
- x 134
At the age of car and the mileage combined it could be time to overhaul the whole release mechanism........even though main box internals could be fine.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
andmcit
- x 30
It could be one of the infamous rods worn over the extremes of the
reverse/first plane?
When you're driving the car, most of the time it's the higher gears which
are predominantly used and even a slow speed first selection may be easier
to engasge with the car moving. I'd say check the easy things like these first:
Item 11 and 12:
Andrew
Item 11 and 12:
Andrew
colski
Thinking about it, it does seem to of got worse when the clutch clip was replaced.
Before that went, the clutch had a high(ish) biting point, however, when the car was picked up from the garage, the biting point was much lower.
Unfortunately, if the gearbox is on its way out, the car will have to go, as I don't have the time and money for this car anymore. Its costing me too much to keep going.
dieselnutjob
Re: Does anyone else think the BE3 gearbox is rubbish?
Classic symptom of a clutch that isn't fully releasing. I bet your clutch pedal is low. Adjust it before it kills the transmission.colski wrote:Also to avoid crunching into reverse I have to select a forward gear then into reverse.
howiedean
I've not had the same problems as you have described, some people have suggested that it sounds like clutch drag?colski wrote:Having had a peugeot 306 1.9td and now a Citroën Xantia, I have found one of the worst things about the cars are the gearbox's.
The issues I've had previously although not serious is that they seem more noisy than the MLT5 gearbox. I went from a 110bhp xantia to a 1.9td xantia and the gearbox felt horrible by comparison, whining slighly.
Regards,
Howie
Howie
2006 Fiat Idea Dynamic 1.3 Multijet
2010 Renault Laguna Dynamique tom tom 2.0 DCI 130
C5 VTR 2l 8v HDI Estate 112000 miles gone
Kia Rio 2007 1.5 CRDI 62,000 miles gone
2001 Dodge Durango 4.7 V8 170,000 miles gone
1999 Ford Crown Victoria 4.6 V8 151,000 miles gone
addo
- Sara Watson's Stalker
- x 95
