ok guys well thanks to jim speedo working but got another problem when my mate took the car for mot he said there is a viberation through the wole car at a certain rpm now then i have done the cambelt all went ok but as i havent driven the car on the road before i dont know if it was thee or not could this be the top engine mount not in correct place or not its not tyres its only at at certain rpm any help please
darren
406 viberation
willy
Hi Darren,
Is it vibrating at a certain rpm when stationary and on the move?
During the cambelt change the engine mount is removed so a check of all those fasteners would be a good idea.
The driver's side wheel would have been removd so I would double check the studs on that as well.
Any other information you have may help such as,
Is the vibration at a certain car velocity or completley rpm related?
Is the vibration coming through the steering wheel?
Willy
Willy
- x 1240
studsmassive
willy
- x 1240
studsmassive
studsmassive
hi guys i ave not cured this problem yet it was not the crank shaft pulley that wasice and tight now is it poss that the pump timing is slightly out as i took it for a blast roud the block and it appears that ist runs out of boost was wondering if this was the cause of these problems thanks
darren
darren
peugeot 406 2.1 diesel
Onlinemyglaren
- x 5631
willy
studsmassive
