406 viberation
studsmassive
406 viberation
Unread post by studsmassive »
ok guys well thanks to jim speedo working but got another problem when my mate took the car for mot he said there is a viberation through the wole car at a certain rpm now then i have done the cambelt all went ok but as i havent driven the car on the road before i dont know if it was thee or not could this be the top engine mount not in correct place or not its not tyres its only at at certain rpm any help please
darren
peugeot 406 2.1 diesel
willy
Unread post by willy »
Hi Darren,
Is it vibrating at a certain rpm when stationary and on the move?
During the cambelt change the engine mount is removed so a check of all those fasteners would be a good idea.
The driver's side wheel would have been removd so I would double check the studs on that as well.
Any other information you have may help such as,
Is the vibration at a certain car velocity or completley rpm related?
Is the vibration coming through the steering wheel?
Willy
x 1240
Unread post by Peter.N. »
I have a vibration on mine if I put my foot down hard between 1000-1500 rpm, I think its the top mount but haven't investigated it yet
studsmassive
hi yes its while on move and you can also feel it while stationary its arround 3000rpm
willy
any luck with finding what's causing it? Any other pertinent info?
x 1240
I didn't realise until I re-read it that it was a 2.1, they are normally very smooth so unless its misfiring I would be inclined to check the crankshaft pulley.
studsmassive
hi i will check the pully today i hope this is the cause
studsmassive
hi guys i ave not cured this problem yet it was not the crank shaft pulley that wasice and tight now is it poss that the pump timing is slightly out as i took it for a blast roud the block and it appears that ist runs out of boost was wondering if this was the cause of these problems thanks
darren
x 5634
Possibly an out of spec injector?
A Lexia session should identify it if that is the problem.
willy
When you did the cambelt did you lock the flywheel, camshaft pulley and pump pulley with screws?
studsmassive
yeh locked them all might be worth taking covers off and puut bolts in again
