Sphere Clicks!!
Ref
Sphere Clicks!!
Unread post by Ref »
i noticed when i depress the brakes while stopping i keep hearing the front sphere clicking continuously and it goes away when i release it. any ideas what could that be?
HDI
x 7
Unread post by HDI »
Flat accumulator sphere I'm afraid !
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
mikep
Spheres - Xantia sx 1996
Unread post by mikep »
Same thing with mine, I'd be interested to learn your quote for supplying and fitting the front spheres. I've been quoted £172 inclusive of vat.
mikep
Citroen Xantia auto sx 1996
Ref
Re: Spheres - Xantia sx 1996
mikep wrote:Same thing with mine, I'd be interested to learn your quote for supplying and fitting the front spheres. I've been quoted £172 inclusive of vat.
I'm in finland so i bet it will be twice as that :(
Sid_the_Squid
Unread post by Sid_the_Squid »
There is a good guide on this site of how to change your spheres. From the description its only the accumulator sphere that needs chaining, not the two front suspension spheres.
Here in the UK a company called GSF can supply an accumulator sphere for a very reasonable price, £22 last time I checked, they might ship to finland.
Its dead easy to change the front spheres by yourself.
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
HDI
x 7
Thats expensive for just 2 spheres, especially as the front are the easiest to do !!
Four corner spheres and the accumulator cost me about £130 and I replaced them myself in about an hour.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
mikep
spheres
I took it to an independent garage and he said he couldn't change them because you need a special tool.
mikep
Ref
Sid_the_Squid wrote:There is a good guide on this site of how to change your spheres. From the description its only the accumulator sphere that needs chaining, not the two front suspension spheres.
is there other possible checks that i need to do to make sure there's nothing else needs to be changed,sphere wise?!!
the sphere would cost almost the same here the cost comes with mechanics who charge 100€/hour :)
x 1475
Re: spheres
mikep wrote:I took it to an independent garage and he said he couldn't change them because you need a special tool.
What - a decent strap wrench and a 12mm ring spanner???? Whereabouts are you - someone may be able to help, or if you are in striking distance of Manchester, Westroen will do them for you for <£30 each.
HDI
x 7
Re: spheres
No, not true. Can be done with a decent pipe wrench, chain wrench, strap wrench etc. Even a big, bolt type hose clamp struck carefully with a hammer will do it !
Also, something I didn't realise, when fitting the new spheres they only need tightening by hand ! It's the O rings that do the sealing job.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
mikep
spheres
I'm in Epsom Surrey, everything is dearer down here !
mikep
Xaccers
x 186
Unread post by Xaccers »
DIY sphere tool
Deanxm
x 87
Unread post by Deanxm »
If you can change a wheel you can change a sphere, it really is that simple, there are guids on here to show you how and im sure members will be more than happy to tell you which part number you need.
It needs changing asap though as if it really is totaly flat it can cause huge damage to the hydraulics if left unchecked.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
Toby_HDi
x 3
Unread post by Toby_HDi »
As said, it can be done yourself. There is a fantastic guide on here:
Spheres, Hydraflush and Brake Bleeding
Talking of tools, I've even had some success with an oil filter wrench (chain type)
or, if you fancy a trip down the M3. I'd gladly help.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
VertVega
x 13
Re: spheres
Unread post by VertVega »
In case you don't want to make your own, here is a picture of this very special tool:
PS: I have no connection to these eBay sellers or items seen in the picture :lol:
Indeed Citroen maintenance is fun and you can enjoy it. Get instructions from FCF 8-)
After you change the sphere, Citrobics should be done:
Gingerposer wrote:Fill kettle. Brew tea/coffee. Sit in car, engine running. Set suspension to high. Sip tea/coffee (biscuit optional). Wait til car has stabilised at max height. Wait a minute or so. Sip tea etc. Set suspension to low. Warning, car may lower suddenly at either end, so don't sip tea/coffee at this point. Once car has settled at lowest setting, resume sipping. Wait a minute or so, then set suspension to high and repeat the process a couple of times.
Jaffa cakes seem to help.
