Berlingo van flashing interior lights
dave28
Unread post by dave28 »
Hi all hope someone can help my van has just started bleeping at me and the interior lights front and rear keep on flashing on and off.i have tried re-opening doors and closing again /turning ignition on and off but just the same.
x 94
Unread post by citronut »
has the battery bee disconected or gone flat at any time,
it might be worth disconecting it and let it sit for i think at least 60 seconds, then reconect it,
but you must not open/shut any doors or bonnet or operate any switch's with the battery disconected for so many seconds as it can upset the BSI,
i think its 30 seconds??
im sure a more knowlegable member will confirm all this, either to be complete rubarb or corect ish
regards malcolm
dave28
Thanks for the reply the battery has not been removed or disconnected at all i have just tried the van again and its ok again at the moment it seems to be after it has been standing for a while .I was just a bit concerned that it was some kind or warning signal for something that was not right.
spider
x 77
Unread post by spider »
They do this if the doors are not shut properly or if you are not wearing a seat belt (on some models)
The seatbelt warning does not come on (along with a beeping) until you are doing say 10 or more mph
Andy.
dave28
i have just worked out that the bleeping starts when the blower is on number 3 and 4
