Xantia S1 one key fob - Frustrating time trying to sync!
Rhothgar
- (Donor 2026)
- x 222
Hi
I have read numerous threads on this topic and a good guide off-site on the forum contributors personal websites.
I have tried to sync my fob but cannot get a response for the life of me.
When I press the button which is nearest the key. I understand this to be the lock function, the red led blinks once and goes out immediately. Not sure this is normal.
On this other forum members website and I cannot remember whose, it shows a picture of the clear led on the front of the key glowing white as white does under a fluorescent disco light. The purpley blue colour.
Mine does not do this?
Does anyone have any further ideas?
I am assuming that because this is NOT lighting that the sensor above the rear view mirror is not receiving any message.
Of course, if this clear LED is supposed to light then that is the problem - but...
what is the fix?
what is the fix?
- x 5690
The clear LED at the front is IR and can't be seen without an aid.
In the form of a digital camera or cameraphone.
Observe the LED through the camera viewfinder while someone operates the buttons, or do it yourself using a mirror.
Don't use an SLR, it won't work unless it has a digital rather than an optical viewfinder.
Rhothgar
- (Donor 2026)
- x 222
Rhothgar
- (Donor 2026)
- x 222
Hi Steve.
Great tip.
it's clearly working. Light stays on for less than a second. I imagine this is normal behvaiour.
I have tried on numerous occasions over the last week to sync this by removing the circuit board and pointing clear LED at sensor above mirror whilst turning ignition key to 1st position.
Could this have anything to do with the fact that my immobiliser is disabled?
Not sure if immobiliser is unplugged or fuse removed?
Great tip.
dnsey
- x 19
Rhothgar
- (Donor 2026)
- x 222
- x 5690
citroenxm
- Fallen Hero
- x 70
The Roof reciver units CAN and DO stop "Learning" a Fob signal! Ive had this a few times!
You DO need a second key, to have the ignition ON... and you need to do it within 20 seconds of switching the ignition on too...
Infra Red light is all in fact NOT RED at all, its a white light... the little red led only tells you the batteries are fine and not flat.
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Rhothgar
- (Donor 2026)
- x 222
Cheers Paul.
I only have one key for the car. So... if I get another one cut presumably a locksmiths will have the blank? Then I could bu a cheap fob off Ebay and use that to programme that fob?
I read in the posts that yo can programme two keys at the same time. Perhaps I misunderstood. Perhaps it did state you actually NEED two keys.
Rhothgar
- (Donor 2026)
- x 222
citroenxm
- Fallen Hero
- x 70
That should work yes!
If you have checked the White light transmitting in a Digital Camera, and it IS sending the signal, chances are then, the reciver in the roof is NOT taking the signal in...
Get another from a scrap yard, and fit it and try again.
This does useually, 99.9 times fix the problem..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Rhothgar
- (Donor 2026)
- x 222
Brigsygtt
Rhothgar
- (Donor 2026)
- x 222
bonnyman750
- x 3
