Leather Steering Wheel Refurb.
Yes, place your time and money saving tips here.Nothing illegal or dangerous please!Motoring related only please.
steelcityuk
Unread post by steelcityuk »
Hi All,
I decided some time ago that something must be done about the state of the single spoke steering wheel in the SED. The leather finish was coming off in various places and the stitching had burst here and there so the initial thought was to buy a better one. However the only one I saw went for more than I could justify so that meant the other options was to swap it back to a 2 spoke wheel or refurbish the one already fitted. One of the things I really liked about the series 1 was that wonderful layout of the dash, switch gear and the single spoke wheel that gives such a great view of it all, so refurbish was the way to go.
Checking the web brought up conflicting advice as to what should and shouldn't be done to leather interiors. The advice that made the most sense to me was that water based 'flexible' dyes work best. So after further searching I settled on a kit from the Furniture Clinic which includes - leather prep, leather cleaner, water based dye, gloss sealer, satin sealer, abrasive pad, cotton wool balls, cloth, foam block, airbrush and propellant.
During the search for the leather repair kit I ordered some waxed linen thread to restitch the leather cover to the wheel. This was bought from an ebay seller and arrived very quickly. Restitching the leather took about 2 hours using the same stitch pattern as was originally used. The thread was 5 metres long so I started in the middle and stitched both ways.
Following the instructions in the kit I put some leather prep on a cotton wool ball and covered it with the abrasive pad (scotchbrite pad), after a good scrubbing, changing the cotton wool ball and using a clean bit of pad, all the leather finish was removed, a good wipe over with more leather prep removed any remaining residue. Next a thorough wipe with the leather cleaner removed the last of the greases/oils that could be contaminating the leather was needed. After this a gentle sanding with 1500 grit silicon carbide paper smoothed out the worn patches and provided a good key for the dye. Another wipe over with the leather prep and leather cleaner was needed followed with about an hours drying time to ensure the leather cleaners had evaporated completely.
Here's how it looks after those first steps -
After several sponge applied coats and a couple of sprayed coats this is how it looks -
TBC
Steve.
not applicable
x 8440
Wow! That looks good Steve :D
steelcityuk
Thanks Jim.
Once this is done the edge of the drivers seat needs attention, it's not worn through yet but has lost most of it's finish on a palm sized area. With luck I may get to have a go at it this weekend.
Steve.
not applicable
Deanxm
x 87
Unread post by Deanxm »
That does look lovely Steve!
I know the wheel you are talking about, i had a bid or two on it but it got to a silly price, oh to have a shed full of leather single spoke wheels, i would be rich beyond my wildest dreams :lol:
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
robert_e_smart
x 14
Unread post by robert_e_smart »
It cost more than a set of Xm alloys could be bought for!
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
andmcit
x 30
Unread post by andmcit »
So I am sitting on a goldmine then?
Andrew
Deanxm
x 87
oh here we go, Andrews going to drop the ass out if the market :lol: :lol:
D
XM Prestige PRV6 92
steelcityuk
So Andrew you're the one that's speculating on XM 'currency' and driving prices up, we'll have to keep an eye on you.:lol:
Today I did manage to remove the drivers seat to examine the worn patch. Considering that the car was built in December 1992 the seat is in good condition.
After cleaning, stripping, a light sanding with 1500 grade silicon carbide, the patch was dyed with a foam block and then blended with several coat from the airbrush.
However I think the bolster is now a darker black than the rest of the seat so that's next.
TBC
Steve.
not applicable
steelcityuk
After many diversions I finally got around to finishing the seat off.
The leather was stripped back to remove all waxes and provide a key, several coats of dye applied followed by a several coats of satin finish then finally 3 coats of gloss finish. Here's how it looks before 'polishing' with leather care.
I think this wraps up the leather refurb.
Steve.
not applicable
