My "love" of all things xantia...and Xm...and Cx..
davetherave
- x 4
davetherave
- x 4
The xm lives and drives again....
Got the pipe on saturday (apparently the last one in the country)!!!
Nice to have brakes again, although they need bleeding badly!
Next job is to sort the clonking suspension out!
Sadly the xantia is not doing so well, after shredding 1/2 its aux belt the engine clonked and died so my dad says!
All good fun, looks like the v6 has fallen through though
, but that means I can concentrate on the Cx!
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
GPZ500s
- x 8234
davetherave
- x 4
Still havnt had time to look over the xantia, its just sat around looking poorly.
The Xm has started riding badly again! think i will need spinal surgery soon, it seems the back end is constantly hard and feels too high
Will have to put it on the lexia and see if anything is thrown up, the electrovalves are definatly working as i can hear them clonk.
Wierdly when i do citrobix, the car bucks when going down as if the valves are opening and closing!
Perhaps my new years resolution should be buy a new car?
GPZ500s
GPZ500s
Deanxm
- x 87
Hi Dave
A reason for bucking around when doing ctrobix can be air in the system, almost all older citroens seem to do it, it could be the feed pipe to the pump is leaking and drawing air in or it could be not enough citrobix have been done since the system was last opened up.
Mine isnt riding badly but since i have re tuned the pressure regulator the car will sometimes jump after settling at normal height post citrobix, sometimes this jump happens as soon as the car settles and sometimes it happens a minute or so later, all the time i can hear the electrovalve buzzing on LW via the stereo so im not sure whats doing it, technicaly the car should be in soft mode the whole time its idling if things are working correctly and so there should be no jumping at all. The only thing it could be is a mechanicaly defective H1 electrovalve, if it was a H2 electrovalve then its likely only one would get lazy and then only one end of the car would jump, the same would be true if it was a mechanical problem with a hydractive block being slow to open.
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
davetherave
- x 4
XantiaDaveEire
- x 4
davetherave
- x 4
Ive been welding the cx for the past few days, and have learnt that if you see fibreglass then leave it alone....
And a view from underneath
None the less it is getting closer to being MOT'd and my sheet of metal is getting smaller and smaller!
Unfortuanaty my welder broke yesterday or rather it stopped regulating the wire speed so it chucks it out at 100mph! Took the circuit board to maplin thinking they could test the transistors but they dont know how
So work has halted on that and to add insult to injury the Xm has dumped all its LHM again so i have no steering/ suspension/ brakes
Will have to take a trip to pleides in the morning methinks
Feeling somewhat depressed! Why did I buy an Xm?? in fact why would anyone buy an XM!!
I spoke to a guy in our village who has just bought a very underpriced v reg BMW tourer that is absolutly mint for £1700. Where previously I have felt pity for these unenlightened people, i felt envious!
GPZ500s
GPZ500s
Citroenmad
- x 110
Thats quite an undertaking you have there! Id have no idea where to start with that
Its a shame, you do seem to have more than your fair share of Xm issues, ive not heard of anyone having so many problems recently. Stick with it, its a good looking car and Xms are different from the norm.
Maybe when you have your CX up and running you might appreciate your Xm a little more, or maybe it will work against it
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
red_dwarfers
- x 58
davetherave
- x 4
andmcit
- x 30
davetherave
- x 4
Citroening
- x 19
davetherave
- x 4
Hopefully it will be at the cxm!
I talked to martin from pleiades after looking at the pipe, and it has failed the same way as the last three.
So it looks as if some bush has failed causing the rack to move and therefore causing the pipes to break.
So as a temporary fix untill the car comes off the road for lots of work, i got this made from pirtek.
Hope it works! Ill fit it in the morning!
GPZ500s
GPZ500s
