Road tax
lexi
x 134
Road tax
Unread post by lexi »
What amount is road tax on the Xantia HDI? Are the later C5 2.00HDI the same?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
DHallworth
x 163
Unread post by DHallworth »
Hi Lexi,
How are you?
The road tax on my girl friends Xantia HDi is £205 a year. That's for a W reg.
If you can find a Y reg they drop significantly but they are like rocking horse crap!
You thinking of replacing the V6?
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
lexi
x 134
I am good thanks. Just looking at the options.
You know yourself David ........you can never really replace a V6 Xantia :D
Cold for car playing aint it? Landy still awaits putting together. I dont' work out there till at least 1 deg C :D :D [/i]
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
DHallworth
x 163
It's waaaaaaay to cold for playing!
I've got a Leon that we're just putting back together after changing the engine.
I've got a Xantia which needs an ABS sensor doing and the side airbag light correcting.
And an XM that needs it's Idle Control Valve cleaning.
I refuse point blank to do any of them when it's this cold though!
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
reblack68
Unread post by reblack68 »
The 2001 Xantia HDi is one bracket above the C5 2.0HDi. I think the Xantia was £145 when the C5 was £110 so I suppose you could add £10 to both these figures.
Richard
No French cars of my own at present.
Care of a 1994 205 D.
lexi
x 134
Thanks Richard. quite cheap for a C5 which is ugly ............but useful :lol:
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
BEST Bet for me is the Higher Tax on the Xantia, and the Better fuel consumption!! Rather then lower Tax and ungly'r looks...
Yes, 6 months rate is £72 on the Xantia, were as the C5 is £65 BOTH APPROX
And un fortunally, the ONLY xantias with cheaper tax are the rare Y reg ones, which most Ive seen so far are 1.8i 16v engine'd ones...
Ive a X reg Xantia HDi, and its still full rate.
There are Y reg HDi's about, but as david says VERY rare!
Paul
A very sad...
1994 XM 2.1 d auto
x 1238
Unread post by Peter.N. »
If registered after April 01, I believe an 2.0 Hdi is £125.00 per year, that's what my newly acquired 406 is anyway.
citroenxm
Fallen Hero
x 70
Peter.
No Xantias after Y reg...
ALL Y Reg Xantias ARE slightly higher to Tax then C5's
Beleve me Ive looked into it!
Paul
A very sad...
1994 XM 2.1 d auto
x 1434
Xantia HDI hatch 154 g/km / £155 (generally, some seem to be 150 g/km!). Estates slightly higher at 156 g/km.
C5 HDi 90 Hatch 152g / £155
C5 HDi 110 Hatch 147g / £125
C5 HDi 90 Estate 155g / £155
C5 HDi 110 Estate 149g / £125
Our Picasso sneaks in under the 150g barrier so is only £125 - I suspect they've put in a longer final drive to get slightly better economy, at the expense of blunting the performance a bit. Or maybe that's the brick like aerodynamics!!
My Xantia was reg in the last week of Jan 2001, so only missed out on being Y by about 5 weeks.... :cry:
x 1238
Sorry Paul, didn't read the post properly :oops: Mine is a 'Y' reg but obviously a late one.
citroenxm
Fallen Hero
x 70
Ah well, you see, if you get a Y Reg C5 HDi's, Yes same year as Last Xantias, they are cheaper to tax aswell...
So your 406 must be a later slightly cleaner 2.oi 8v lump...
Paul
A very sad...
1994 XM 2.1 d auto
jmd
Unread post by jmd »
Consider yourselves so LUCKY Road tax on an 01 Xantia or C5 here in Ireland is €620-00 annually. Still about half that if the C5 is year 2008 or newer. Since they started to tax on Co2 emissions then, & did'nt make it retrospective on older cars.
dieselnutjob
Unread post by dieselnutjob »
when I bought my 607 it was cheaper on tax to get an older one as the C02 on a 2.2HDI auto is quite high.
I also have to pay full rate for my ultra rare 1976 Peugeot 604 as apparently it's not 'historic' :roll:
Citroening
x 19
Unread post by Citroening »
£425 a year for the C6... :( :( :x
Franklin
