zx estate rear suspension
tony1961
Unread post by tony1961 »
hi there, ive noticed in the last couple of days the rear suspension seemed stiff. today i noticed that the car rear was hard when driving, anyway i got home bounced on the tow bar there was no movement. does anyone know what the problem could be it seems to be on both sides. could it be the shockers both gone at same time!!.it would be a great help before i go under the car in freezing conditions
evilally
x 3
Unread post by evilally »
At a guess, there's a problem with one of the dampers and it's stuck. I would imagine that the ARB will make the other side difficult to move if one side is stuck.
'96 405 1.6 GLX with 306 GTI engine on Cat cams @ 195bhp
'05 RenaultSport Clio 182 Cup, 102k
'97 406 1.9TD, 314k.
x 1239
Unread post by Peter.N. »
It could be that snow/water hs got into the damper casings and frozen, if you can manage with it until the temperature rises a bit you will find out. Alternativly you could try blowing them with a heat gun or hairdryer.
tony1961
zx sus
thought it might be something with the cold temp but didnt think it would be poss, -10c at this moment in keighley west yorks will try with heat gun tomorrow thanks tony
x 94
Unread post by citronut »
or at worst its your axle lost all of its travle and she's on the bump stops,
do the rear wheels look like they are leaning inwards at the top/s / \,
does the rear of the car look level with the front
regards malcolm
tony1961
zx
hi i went under the car this morning looked at the dampers they seemed ok. i warmed them up any way with heat gun. also put penetrating oil onthe arms were the bearings are. now it has movement. idont think its 100%. yes the wheels are pointing in at the top just waiting to find a rear axle to refurbish and fit thanks tony.
x 1239
Ah! If your wheels are leaning in likely all the grease has gone from your trailing arm bearings and they have probably filled up with water.
