Citroen Relay engine swap XUD advice
warren555
Okay, so water pump and timing belt in hand it's time to start putting this all back together.
All I need now are the torque settings for the water pump and crankshaft bolt. Does anyone have these to hand?
Alex, I am curious about the car destroyed by Kent police. Any fantastically interesting story behind it?
Cheers,
Warren
Cheers,
Warren
- x 8411
warren555
- x 8411
Chlorate
Not really, some 'orrible little oik from Folkestone stole it from outside my house and dumped it somewhere. The police found it and towed it away and held their hand out for £150 to get it back, £75 to scrap it and £15 a day every day they had it.warren555 wrote: Alex, I am curious about the car destroyed by Kent police. Any fantastically interesting story behind it?
Couldn't afford £150 for a car I didn't use, uninsured and untaxed too...so I'd have to pay someone to tow it back too
I liked that car, although the ZX is much better...when it works
-Alex
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police
previously:
warren555
Ahh. I was hoping for something along the lines of some dangerous terrorist stole it and it was destroyed by a cruise misile fired from the deck of the HMS Invicible as she was moored somewhere in the Med.
Still, yours was not a bad story.
Have your shims turned up yet?
Thanks for the sentiments Jim.
Chlorate
T'was a bit of a wind up. Apparently they got him, and he's been put inside for a number of things now, which is a little bit of justice. But my brother still doesn't have a little 106 to drive when he finally learns to drive.
Shims not turned up yet; I know they're on their way,chap from Tate's Citroen rang me on saturday morning asking for a delivery address. Hoping they turn up soon. Bloody Royal Mail.
I did a very silly thing and left the notepad where I scrawled down which shim has to go where in Brighton
Lucky my housemate hasn't gone home yet.
-Alex
-Alex
previously:
previously:
warren555
citroenxm
- Fallen Hero
- x 70
Tighten the crank bolt WHILE the locking pin is still in the Flywheel!!!CitroJim wrote:Excellent Warren.
water pump bolts are 11mm so they don't need to be fantastically tight. 12 Nm or 9 ft lbs is the recommended.
The crank bolt is done up to 40 Nm (30 ft lbs) initially and then angle tightened a further 60 degrees. In other words, well tight.
I use a TINY bit of threadlock on the Crank Bolt too....
I have seen what happens when the crank bolt undoes a little and the crank pully batters the crap out of the key way, and the crank bolt then sieze's in the crank!! Serious, its SERIOUS CRAP!!!
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
warren555
warren555
Very frustrating day.
Do some work, rain, stop. More work, off to motor factors. More rain.
Some work, off to motor factors. Rain etc etc.
If nothing else, I learned today to make some sort of order for my work and get everything I need before starting.
Paul, I went to the motor factors twice today and still forgot to get the threadlock.
Still, I got the water pump on and managed to get all the locking pins and bolts in place.
Jim, when you gave me your instructions regarding a seized water pump, you mentioned the fact that the Bosch turned as if it was going through compression strokes. When I timed up the fuel pump, it locks in at about 1 o' clock which it right in the middle of a "compression stroke". Does this seem right to you? I did not see any other bolt holes so assumed this to be correct.
Well tomorrow is another day so hopefully I will have some more progress.
I was thinking about when the belt is on. Is it best to remove all the timing bolts and pins and then turn the engine by hand (ratchet) via the crankshaft bolt, just to make sure it is all lined up correctly.
A complete aside that I forgot to mention at the begining. I am not the weakest bloke in the world but I am no Mr Universe either, but I managed to tear the timing belt off. It took as much force as to tear a piece of cardboard and just tore with one go from side to side! This can't be right, can it?
citroenxm
- Fallen Hero
- x 70
The pump TIMES AT 4 o clock, and yes its in the middle of a compression stroke..
MAKE sure you are timed on the correct hole on the pump, theres TWO holes on the pump.. for other reasons... One at 12 one at around 4pm...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8411
No, that's not right at all. A timing belt should be very tough indeed. In my experience they even take a bit of cutting with a Stanley knife. In no way should you be able to tear it with bare hands.warren555 wrote: A complete aside that I forgot to mention at the begining. I am not the weakest bloke in the world but I am no Mr Universe either, but I managed to tear the timing belt off. It took as much force as to tear a piece of cardboard and just tore with one go from side to side! This can't be right, can it?
warren555
Right. My pump has three holes on the pulley. One spoke has one hole. Another spoke has a hole the same size as the first one and a smaller hole beneath it. When I lined it up the bolt sits at about 1 o' clock.
I am just going outside now with a torch to see if I can see another bolt hole, but I did not see it earlier.
warren555
