My rear hub bearings are starting to rumble slightly, although there's no play (just passed MOT).
There's lots of info about replacing the hub, but I could only find this...
http://www.frenchcarforum.co.uk/forum/v ... b+bearings
...about re-greasing.
The Haynes manual says the bearings will be destroyed if the hub is pulled off. Is this true or not?
I presume I can only re-grease the outer bearings without removing the hub?
If I do decide to replace the hubs, and reading through the hub replacement threads, it seems like I need:
1. To check the rumble with a piece of steel between hub carrier and my ear.
2. Have correct socket and a big extension bar.
3. Hub puller...which is best, the claw type or the flat plate type? If a get a puller for the inner race (below0, it looks like the flat type of puller is needed.
4. Angle grinder or additional puller something like this to get off the inner race:
http://www.machinemart.co.uk/shop/produ ... -040211226
Thanks in advance for help/comments/answers.
Regards
Martyn
Xantia II (1999) - re-greasing rear wheel hub bearings
mrjohnson
- x 1449
You missed this (short) thread.
I think you can force enough gease in through the outer race that some will find its way to the inner. Removing the hub tends to ruin the inner seal rather than the bearing.
Old-Guy
- x 24
Gone are the days when strip-and-repacking of wheel bearings was a scheduled service item. Modern grease should last the life of the bearings, so replacing a complete wheel-bearing set is 'standard practise' (whether DIY or professional).xantia_v6 wrote:I think you can force enough gease in through the outer race that some will find its way to the inner. Removing the hub tends to ruin the inner seal rather than the bearing.
For the labour involved, it makes no sense to 'service' a bearing set that is close to the end of its life.
reblack68
Kowalski
I re-lubricated the rear wheel bearings on my old Xantia by taking the outer cover off, sticking the nozzle of an oil-can into the bearing and pumping some oil in. After I added the oil, I put some grease onto the outer bearing to stop the oil from coming out again. The grease tends to dry out over time and adding some oil should turn it back into grease again.
VertVega
- x 13
I also lubricated them long ago (many years) and they still keep on rollingKowalski wrote:I re-lubricated the rear wheel bearings on my old Xantia by taking the outer cover off, ...
Both rear bearings are originals (200k Plus miles)
They were both already dryish then, left rear drier.
The same cover back on and gently tapping all around, it stayed without any problems.
mrjohnson
Thanks for the replies.
I need to have a proper listen to check if one or both bearings are getting noisy. Then I think I'll try injecting gearbox oil into the bearing. I might try putting some in the freezer to see what it does to the viscosity...if it goes thicker it may stay put better before the cap is replaced.
VertVega & Kowalski - did you have to take off the hub nut to do this?
Cheers
Martyn
Cheers
Martyn
VertVega
- x 13
I have only removed the cover. Then you'll see the bearing balls and also see the grease amount and condition.mrjohnson wrote:...
VertVega & Kowalski - did you have to take off the hub nut to do this?...
(There's a pic of it and I might edit this message later...)
I used only bearing grease.
Edit: Here's a close-up of the rear bearing right from the shelf, unused
You can see the grease which is already quite thick and see how it's applied.
This tends to get dry.
From the gap seen in the pic (the big nut side) I have added new grease.
citroenxm
- Fallen Hero
- x 70
it does NOT destroy the bearings if you remove the hub!!
What it does do, is it splits the inner set of balls from the inner bearing race, leaving the inner race on the stub... HOWEVER, if this appears to be in good order, its not a problem, providing the balls in the bearing all stay intact.. and the race looks in good order... you can then completely and utterly stuff the thing with grease! As for refitting, the washer and large nut pushes it all back home nicely!
I have TWICE now, replaced a noisy bearing with a quiet one, of course, they were hubs and bearings, the inner race staying in place both times, and have successfully worked...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
scottishpaul
