Cassy's regulator is leaking from the 12mm bleed screw.
Jim and I thought it was actually veg running down from the injectors due to a failed leak off pipe, and after cleaning the area it seemed to be sorted, but the leak is back, I'm using about 500ml of LHM every few weeks.
So what's likely to be the cause?
I remember yonks ago plenty of threads talking about hitting the ball with a brass punch, but can't remember why.
Regulator leaking from 12mm bleed screw
Xaccers
- x 188
DIY sphere tool
DIY sphere tool
Deanxm
- x 87
Xac, its highly likely that the seal on the bleed screw itself is shot, its like an 'o' ring, its easy to see once the screw is removed. should be cheep enough.
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
VertVega
- x 13
Deanxm
- x 87
OnlineCitroJim
- x 8309
Kowalski
Deanxm
- x 87
OnlineCitroJim
- x 8309
Deanxm
- x 87
OnlineCitroJim
- x 8309
- x 94
Xaccers
- x 188
Do you have the part number for it?VertVega wrote:According to service pages data, the O-ring mentioned by Deanxm is diam. 6 TO 1.9 .
Don't loose the metal ball (diam. 7) as I did once
At nearly 14 years old, so far all the usual o-rings have needed replacing so I'll try that first.
DIY sphere tool
DIY sphere tool
VertVega
- x 13
Deanxm
- x 87
the o ring does provide the seal, o rings seal the main components of the regulator itself and the FDV is sealed with o rings alone.
I wouldnt of thought that they take the pressure either but they do.
D
D
XM Prestige PRV6 92
Xaccers
- x 188
Replaced it today, remove the 12mm bolt, caught the ball and about 500ml of LHM.
The old o-ring was flat and rock hard, had to snap it to get it off, fitted the new one and put it all back together (remembering the ball).
Topped up the LHM so will see how it goes.
DIY sphere tool
DIY sphere tool
