306 rear anti roll bar?
wiggie_me
Unread post by wiggie_me »
is there a anti roll bar that goes through the middle of the beam? somthing crunched a week ago and since then when the arse of the car has been very wobbley at speed.
i have just replaced the dampers with no change. could an anti roll bar snapped??
wiggie_me
Re: 306 rear anti roll bar?
wiggie_me wrote:is there a anti roll bar that goes through the middle of the beam? somthing crunched a week ago and since then when the arse of the car has been very wobbley at speed.
well that sounds like i never went to school, i cant multi task. but im sure u can understand what i meant.
x 1477
Yes, there's a roll bar through the middle splined into the centre of each trailing arm bearing. It's possible you've broken a trailing arm bearing or sub frame mount - I can't really see how the ARB could make it 'wobbly' at speed. How do mean crunched? Under what circumstances? Are the wheels still vertical when viewed from behind the car?
eddie123
Unread post by eddie123 »
Yes there is a roll bar. Very strange for it to just snap?
wiggie_me
turned out to be a very worn wheel bearing. cant believe it wasnt making a noise? it all fell out in bits!
