what battery should my xantia have ?
imperial21
Unread post by imperial21 »
Hi All
what battery should my xantia have ? its 110 hdi exclusive.
the battery fitted is a renault one which says 47ah 420a
In the cold mornings i am finding the car very slow turning over and the gauges go a bit mad ! i dont want the dials to stick as suggested they can.
I think the battery is a petrol one ? My cars previous owner did nt exactly look after it which has caused me so many questions ! :oops:
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
Chris570
x 36
Unread post by Chris570 »
096 i think
go to www.eurocarparts.com and type in your reg it'll show you what the car is meant to have
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I hope the previous owner didn't fit Renault spheres as well? They're bloomin' awful!
x 1240
Unread post by Peter.N. »
Certainly sounds to small for a diesel.
VertVega
x 13
Re: what battery should my Xantia have ?
Unread post by VertVega »
imperial21 wrote:... 47ah 420a...
It is too small for a HDI 110 :(
I have petrol Xantia and I would not use that in mine :?
I checked from exide web pages according to your car's specs. They have a nice battery selector.
UK --> Xantia --> 2.0 HDI --> Battery
1. Starter Battery PREMIUM ***
Voltage: 12 V,
Battery Capacity: 64 Ah,
Cold-test Current, EN: 640 A,
Length: 242 mm, Width: 175 mm, Height: 190 mm
2. Starter Battery EXCELL **
Voltage: 12 V,
Battery Capacity: 62 Ah,
Cold-test Current, EN: 540 A,
DHallworth
x 165
Unread post by DHallworth »
Although it may be smaller then what the specifications recommended for the car are I wouldn't be rushing out to replace it.
As long as it's turning the car over and starting it without it being sluggish then I wouldn't be spending money replacing it personally!
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
x 1240
Trouble is it won't last long, especially when the weather gets colder.
HDI
x 7
Unread post by HDI »
If the battery voltage is falling low enough to cause erratic gauges then it's too low. You may find the radio will need the code entering when the weather gets much colder.
At some point the battery will fail on a cold morning if it's struggling now.
Plates may buckle on the lowest cell in the chain, this will cause an internal short which drop the voltage on one cell.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
brmartyn
Unread post by brmartyn »
3 X AAA :lol: :lol: :lol: :lol: :lol:
Brady
Citroen C8 2.2 HDI Exclusive 2006/06
Previous French cars -
Renault Megane Tourer 2004/54 1.9 DCI Privilege
Citroen Xantia 1998/S 2.0 16v Exclusive Automatic
Renault Laguna Sports Tourer Dymanique 2001/51
Citroen Saxo VTR 2000/W
imperial21
On monday morning the car only just started,it was very sluggish it was then i looked at the battery but thought it looked new, till i read the label & megane al fairly small renaults :) :)
its pay day tommorrow i think i may treat the car to another battery before it dies.
the little green light on the battery is good !
rory_perrett
Unread post by rory_perrett »
Probably a sign that it is on the way out. Modern batteries seem to "fall off a cliff" one day they work, the next they don't. Also not using the car for a couple of days seems to show it up more. First cold day on Sunday and the Xsara HDi, which had not been used since Thursday wasn't having any of it. Modern cars just need so much power, turn over speed was not that bad but there was no way it was going to start. Less than an hour on the battery charger and it was fine for the rest of the day. Didn't take a chance and in went a new battery by the end of the day.
VertVega
x 13
Peter.N. wrote:Trouble is it won't last long, especially when the weather gets colder.
I agree 100% with Peter.N. It is a bad surprise when you are looking for a jump start help, on a cold morning.
I bought a new one last June before going on the summer holiday.
Previous one was in use for 8 years and never disappointed 8-) Same brand is in engine bay now.
Be prepared for sky high battery prices. I was told that the prices have gone up since last 2 years :shock:
HDI
x 7
Problem is worse with an engine managed car, there is a minimum cranking speed set in the engine map, anything below that means no go !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
addo
x 95
If the battery telltale is green, then the battery should be all good - my experience is the telltale expires to a dead blackness long before the battery is kaput.
Could it not be the starter? (Very topical issue at present!)
HDI
x 7
good point !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
