Info on early Hdi engines
x 1240
Unread post by Peter.N. »
OK thanks Paul. The Hdi XM sounds good to me but I'm getting a bit long in the tooth for projects like that now.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
I didn't mean you Peter, Its a project that I WANT to do! I have an engine and ECU spare to do it with, just need to unlock the ECU!
Paul
A very sad...
1994 XM 2.1 d auto
dieselnutjob
Unread post by dieselnutjob »
citroenxm wrote:Funny, reading this thread, that ALL Citroën contributers replied, and only one Peugeot replyer...
I can see three including myself.
Also, even if it does have a DMF they can be swapped for a Valeo four part conversion kit which my 806 has.
x 1240
Perhaps I should have posted in the Citroen section then :?
Paul, OK on that, I shall know where to come for advice then! :D
Citroenmad
x 110
Unread post by Citroenmad »
I agree with everything which has been said, the 2.0HDi 110 8vs are brilliant engines.
You have thought about a Xantia 2.0HDi estate then Peter? Not quite as big as a 406 i dont think, but probably more comfortable.
C5s are coming down in price now, there are some real bargains to be had and the estate has a good, square and spacious boot.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 1240
Hi Chris
I am slowly being converted to Hdi, I had thought about a Xantia but its got all the agro of the XM but not all the perks, I am still running an XM estate but have almost given up on getting another nice late one - unless you want to sell yours of course :D
My wife did have a nice ZX estate but in a moment of madness I sold it to a friend of ours and bought the 5 series, not really my cup of tea, maybe 40 years ago :? I thought of the 406 as its still relativly simple, or at least the early ones are and I think the ride is passable but I am open to suggestions.
Citroenmad
x 110
Your best bet would be to find a Y reg 2.0HDi 110 406 estate, that way it should not be multiplexed but it will have the cheaper road tax.
I dont think anyone has answered the DMF question yet, i think a Y reg 406 will have one, though im not sure when they were introduced, it could be that all 406 110s had them.
Your right, a good Xm is getting hard to find now, especially an estate, like hens teeth.
03 Seat Arosa 1.0S
dieselnutjob
My understanding has always been that the 90 bhp has the BE3 gearbox and hence a standard clutch whilst the 110 bhp has the ML5 gearbox which has a "pull" type release mechanism and therefore a DMF (unless a Valeo conversion kit has been fitted).
So, does the Xantia HDI 110 bhp (without DMF) have a BE3 or an ML5 gearbox?
Also is it correct that all BE3 transmissions have a cable operated clutch with the bellcrank thing on top of the transmission, whilst all ML5s are hydraulic?
If so then it's quite easy to tell when looking at a car which transmission it has and therefore whether it has a DMF or not.
x 1464
Xantia HDi 110 uses a ML5 box with Hyd clutch, but no DMF....I was led to believe that the 406 110 HDi always had a DMF :?
citroenxm
Fallen Hero
x 70
2004 Pug 406 HDi 90's switch to Hydraulic Clutch! Serious! Ive seen one! and it was defenatly a 90bhp too!!
I would have thought the 406 would have switched to DMF in 2000, when citroen switched to the C5, as no Xantias had DMF's as said above...
Paul
A very sad...
1994 XM 2.1 d auto
KP
x 27
Unread post by KP »
IIRC the injectors are a nightmare to get out on th 16v models are they not??
I've had a 90bhp estate xantia and it was fine other than the fuel cooler being a PITA and underpowered, and my dad has one in his mk1 C5 and its worked without issue since he bought a year or two ago and it has silly low miles, circa 50k for a 52 plate car :)
x 1464
citroenxm wrote:2004 Pug 406 HDi 90's switch to Hydraulic Clutch! Serious! Ive seen one! and it was defenatly a 90bhp too!!
Our 2003 Picasso HDi 90 has a hydraulic clutch on a BE3 (4?) 'box... one of the main reasons for buying it over a Berlingo, which used cable clutches, and all the ones we tried were heavy - not good for bad backs!
110 HDi is FTW - 90 is rough and underpowered by comparison - pity that the Picasso only comes with 110 BHP in 1.6 HDi FAP form - can't afford one of those yet, and it could do with a few more horses under the bonnet :evil:
citroenxm
Fallen Hero
x 70
Sorry, dumb moment here - FTW????
Paul :oops:
A very sad...
1994 XM 2.1 d auto
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
i thought it was for the world lol , but urban dictionary has it as 'for the win'...
citroenxm
Fallen Hero
x 70
Can it be then - TDB ... Rude yes, but The Dogs B+++++?? :D :D :D
Paul
A very sad...
1994 XM 2.1 d auto
