C5 ( Mark 1 ) HDi 90 Aux Belt
KP
x 27
Unread post by KP »
Does anyone have a guide or tech doc on how these should run and be tensioned as my dads has snapped clean off and while he has another belt to put on is not sure how it should route or tension.
Also do these run the AC compressor?
Thanks,
Will
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Yes they do run the Air con compressor... Its basically the same setup as late Xantias..
Firstly release the eccentric roller, lower down, through the wheel arch, then the belt route as follows: OFF the TOP of the crank pully, UNDER the SPRING loaded upper tensioner, up over the PAS PUMP, then down to the ECCENTRIC, around the ECCENTRIC back towards the TOP of the ALTINATOR, then DOWN to the AIR CON pully and to the bottom of the crank...
You may need a 14mm spanner to lift the upper tensioner to get the belt in!
Once all in route, swivel the Eccentric tensioer with a square drive and so it takes up the slack and puts load on the spring tensioner... Tighten the eccentric (8mm ALLEN KEY)...
Paul
A very sad...
1994 XM 2.1 d auto
KP
x 27
Unread post by KP »
Cheers Paul. Sure that will help my dad :)
Its stupid you can't find anything like this on service box even after 30mins of searching :(
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Here's Autodata's piccy:-
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
citroenxm
Fallen Hero
x 70
Thats the one!! Preciesley right!
Paul :lol:
A very sad...
1994 XM 2.1 d auto
KP
x 27
Unread post by KP »
Amazing Thanks guys!
KP
x 27
Unread post by KP »
Cheers guys,
My dad managed to get it done last night.
Will find out when i next see him if he got the right belt for the AC as im sure he has previously said that the compressor wheel had no belt round it which would explain why the ac never worked...
x 1931
If the belt has been off the compressor for some time then it still may not work as the refrigerant could have leaked away.
Chris570
x 36
Unread post by Chris570 »
i would wonder why it was off (presuming it was deliberate)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
citroenxm
Fallen Hero
x 70
Dodgy Electro magnetic clutch likely...
But its defenatly driven by the same belt.
Paul
A very sad...
1994 XM 2.1 d auto
KP
x 27
Unread post by KP »
We will see.
I think its down on refrig as well but i can recharge it myself once i replace the pressure gauge :)
