I swear this car is trying to wind me up...
First the accelerator cable comes free and now this.
Ah well.
To business, is this gonna mean I need a new door lock and ignition barrel or is there a way to get a replacement key?
Even though the key I had wasn't an original; it fits the driver door, the ignition, the glove compartment lock and the (what I think is) alarm on/off thing under the bonnet.
So I'm guessing it was a replacement for the original key.
Would I be able to ring up a stealer with my chassis number to get a replacement, or would any locksmith be able to make a replacement from the broken bits?
-Alex
ZX Broken key
Chlorate
ZX Broken key
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police
previously:
spider
- x 77
If its the original the dealer might have the key blade code, but I am not sure.
When they were new (depends on age I think) you got a small tag on each set of keys with the number if you ever needed a new key.
Not to be confused with later transponder key codes, the tag is the actual key number.
A good locksmith should be able to make a key out of the broken parts though.
Andy.
Chlorate
This car seems to have a questionable history at best, hard to tell which bits are original and which aren't, and no sign of a key number anywhere. Thankfully tis an old key so no transponder to be found here.
Managed to recover the broken off bit from the lock, so it's a case of walking around the locksmiths of Brighton to see if anyone can do it.
No chance someone's familiar with Brighton locksmiths?
-Alex
-Alex
previously:
previously:
handyman
There is a good hardware/architectural ironmonger in the North Lanes, Brighton, can't miss it as it is a ***kin' big shop. They should be able to do it.
I had the same problem with my ZX, but the key snapped in the ignition lock.
Managed to retrieve the parts.
I now have Peugeot locks on all my doors as they do not wear like the useless Citroen ones.
H
H
