Often wondered
lexi
- x 134
Often wondered
Can the V6 Xantia take any kind of roofbars? I have two sets which fit the xantia estate with t track.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
jgra1
- (Donor 2021)
- x 36
no Lexi V6 (hatch) needs the hatch roofbars (unless you have a V6 estate, I think these exist.. >)
roofbars are different to estate ones, they have 4 brackets that screw in above the doors into the roof, and (on mine at least) the bars clamp to the brackets..
I leave my clamps in all the time and add bars when I need them.. also makes it handy finding the xant in a busy car park
- x 8272
Hi Lexi,
If you peel back the gutter strips above the doors, you'll see these:
This is where the brackets screw into.
If the car has never had a roofrack fitted, you may see this:
If the protective caps have deteriorated, it can cause a water leak into the car...
As John says, bespoke roof bars are needed...
lexi
- x 134
Ah Right!. Thank you gents. Any pic of what the bar looks like at the attach ment point?.............could I fabricate a bracket onto my estate bars?
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
