Xantia Suspension Oscillation (Fixed! solution on page 2)
bostwickenator
I have a Xantia 96 estate (petrol 2.0i, auto, hydractive) and wondered if anyone could help me answer a few questions about the suspension. I find that when I hit bumps in the road I fairly often (depends on speed and bump shape) get a oscillation or harmonic if you will. The car will bounce up at the front then the back then oscillate between the two noticeably 3 or so times. In another car I would say it felt like soft shock absorbers but I wouldn't have a clue with a Xantia *lol*. Turning hydractive to sport (light on) makes the ride a little less disconcerting but not what I would call sporty. I believe the sphere's have leaf valves that do the damping? Do these get weak over time? I should also mention that the rear end drops quite rapidly after engine off. Sometimes it can take five minutes sometimes 30 seconds.
Any answers or pointers would be appreciated, I'm quite out of my depth here.
Dommo
- x 20
Do you know whether the spheres have ever been changed? There's 8 on a Hydractive anti sink car!
Healthy Citroens could be described as bouncey to most people, it depends on how severe the bounces are. If it's a harsh bounce some of the spheres sound low on pressure and need replacing, however if its a slow wallowey bounce over a speed bump for example, that's fairly normal,
bostwickenator
Unfortunately I don't know if the spheres have been changed. Is there a way to test their pressure?
The bouncing is wallowey at around 60hz so it seems very noticeable. My previous Xantia felt very different but it was the Hatch and didn't have hydractive so maybe it is just that.
Just to make sure I understand correctly old spheres with low pressure will cause sharp bumps because the gas has less of a cushioning ability? Where as 'good' spheres will give a bouncier more floating ride. If my old spheres were flat I think I preferred that +_+.
Jimothy
My old Xantia developed this problem - it is linked with the loss of nitrogen gas from the spheres, I believe.
I read that the spheres can be "topped up" if the loss is within certain limits, but if they've gone too far then the spheres need replacing, which is an expensive job in my experience, so get it looked at sooner rather than later.
Don't reckon that's right BTW (if it is then it's not the same problem afterall) - 60Hz means 60 cycles per second, which would feel like a buzz (like driving over a cattle grid at speed) rather than a bounce.bostwickenator wrote:around 60hz
DickieG
- Monaco's youngest playboy
- x 33
The problem could be down to some sphere's being low on gas or having the wrong sphere's fitted, they can be tested for pressure, I and one or two forum members have sphere pressure testers, whereabouts are you as I'm willing to test them for you.
As for the rear of the car dropping that may well be down to the rear Hydractive block not closing which could also be a cause of the wallowing as that could mean that the rear of the car is permanently stuck in soft mode. Have you tried pushing down on the suspension when the engine is running then turning it off closing all doors, waiting for 30 seconds after which the Hydractive suspension should switch off (you should hear a faint click under each end of the car and a buzzing noise stop) then again pushing down on the suspension, at this point the suspension should have switched to firm and be harder to push down on.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
bostwickenator
Unfortunately I'm in New Zealand so it would be a bit of a trip to get the spheres to you. I'll check with our local Citroen branch and see if they can test them for me.DickieG wrote:The problem could be down to some sphere's being low on gas or having the wrong sphere's fitted, they can be tested for pressure, I and one or two forum members have sphere pressure testers, whereabouts are you as I'm willing to test them for you.
As for that test you described I'll do it as soon as my girlfriend gets the car home. I figured the humming would be related to the suspension but the manuals don't mention it.
bostwickenator
Very interesting I'll definitely ask about this at Citroen hopefully it is somewhat cheaper than a new set. And you are completely right about the speed I in fact meant 1Hz. (I've got to start proofreading)Jimothy wrote:My old Xantia developed this problem - it is linked with the loss of nitrogen gas from the spheres, I believe.
addo
- Sara Watson's Stalker
- x 95
- x 1459
kevlights
you may need a spheres and LHM flush out with filters clean
http://www.fastfrogs.co.nz/index.php
http://www.fastfrogs.co.nz/index.php/topic,5719.0.html
http://www.trademe.co.nz/Browse/Listing ... =324761990
and for some home work this
http://www.attfield.dircon.co.uk/Hydrau ... Xantia.pdf
explains the ins and out of the suspension
next time you are passing a car sales yard take the Citroen you see on sale for a run to compare with yours ,cheap comparo info to be had first hand!!
- x 1240
citroenxm
- Fallen Hero
- x 70
Theres always a problem with "Newer" owners to Citroens identifying the citroen "Bounce" and "Float"
Im not point the "Newer Owner" description at you, bostwickenator, or anyone in particular..
Theres a VERY obvious difference with the Flat Bounce and the Gass Float!
The bounce gives a sort of "Rubbery" type of Flex bounce, were as gasses spheres give a nice smooth floaty bounce, its NOT a bounce really, more like a Shot shock absorber on lesser "Normal" boring cars...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1459
bostwickenator
addo
- x 95
It's also well possible your front ride height's excessive. Have a look about halfway down the page in this linked thread, for my photo of unmolested ride height at the front with motor running.
http://www.frenchcarforum.co.uk/forum/v ... c&start=15
