Xantia 2.0HDi Plip problems (RF)
jcdel
Once again my plip has gone Kaput.I swapped my previous Xantia one with a s/h unit but that was an IR version.Can we adopt similar reprogramming methods or is this a no go.Is it the dreaded main agents. Thanks for any news good or bad
spider
- x 77
MikeT
- x 232
What does Kaput mean in this case? Can it not be fixed/repaired?
Until recently, I would have said it can programmed without a Lexia but there's now some doubt about this being true for unoriginal key/fob combinations.
The handbook tells how to re-synch a fob after replacing the battery, for instance.
Simply insert key and turn ignition so the immob light goes out (no need to start the engine) then push the button (then other buttons in turn) within 10 seconds IIRC. That should do it.
jcdel
- x 1489
MK1 IR types can be synched to the car just by pressing the button with the ignition on. MK2 RF types cannot - you need a Lexia to program the fobs to the car however MK2s also have an immobiliser chip in the key, and it might not be possible to re-program the chip to a new car if it has already been programmed (see thread about the C5 keys).
MikeT
- x 232
You don't need a Lexia to re-synch the RF remote fobs, though I don't know if that's true for the initial synchronising (ie a new fob)RichardW wrote:MK1 IR types can be synched to the car just by pressing the button with the ignition on. MK2 RF types cannot - you need a Lexia to program the fobs to the car however MK2s also have an immobiliser chip in the key, and it might not be possible to re-program the chip to a new car if it has already been programmed (see thread about the C5 keys).
As for programming a used key (chipped), I'm still unable to find any info on the process. I still believe you can and, given the chance, would like to test my theory.
- x 1055
on a car with an RF plip & a CPH unit (ie xantia 2) You neeed a Lexia + the 4 digit transponder code to program a new remote plip.MikeT wrote: You don't need a Lexia to re-synch the RF remote fobs, though I don't know if that's true for the initial synchronising (ie a new fob)![]()
Don't know if second hand ones are reprogramable to a different car.
MikeT
- x 232
I know that is true for the key's transponder and that remote fobs are programmed at the same time but...wheeler wrote:on a car with an RF plip & a CPH unit (ie xantia 2) You neeed a Lexia + the 4 digit transponder code to program a new remote plip.MikeT wrote: You don't need a Lexia to re-synch the RF remote fobs, though I don't know if that's true for the initial synchronising (ie a new fob)![]()
The distinction I'm trying to make is, you don't need a Lexia to re-synch the original RF fob(s) (from a MK2 Xantia according to my handbook). This suggests, that new fobs or used fobs (not key transponders) might also be programmable without a lexia.
- x 1055
MikeT
- x 232
citroenxm
- Fallen Hero
- x 70
It IS Very possible to program a second 2nd hand plip to a S2 Xantia - but you DO need two things - Thats a Lexia, and the cars original KEY CODE.. not the replacment keys code.... the cars original..
Ive done this for a mate, however, not worked out how to get his "New" key to start the car, only unlock it...
paul
paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
MikeT
- x 232
citroenxm wrote:It IS Very possible to program a second 2nd hand plip to a S2 Xantia - but you DO need two things - Thats a Lexia, and the cars original KEY CODE.. not the replacment keys code.... the cars original..
How did you program the plip only? From my key programming experience, the key transponder is programmed first THEN the remote fob. A failure at the key transponder should halt the process, disallowing remote programming. Is there a "remote only" section?
citroenxm
- Fallen Hero
- x 70
Oooo cant remember off top of my head now... Id have to go into the menu's and look, there was a "Key LEarning" section, this was for the locking only though Im sure...
It was a while since I done it..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1939
Did you put the working, original, key in the column lock and then do the lock button procedure on the spare?
- x 1055
I suppose when it asks for number of keys to be programed you could enter 0 but you would think it would suspect something not right & not let you continue ??MikeT wrote: How did you program the plip only? From my key programming experience, the key transponder is programmed first THEN the remote fob. A failure at the key transponder should halt the process, disallowing remote programming. Is there a "remote only" section?
