Xantia L reg questions
admiral51
(Donor 2026)
x 394
Unread post by admiral51 »
Hi all
As stated in the for sale section i have aquired a 1.9 td with a few minor problems.
The engine has recently been replaced and i need a few questions answered :)
As can just be seen in this pic the breather pipe from the oil filler is not correct.
If you look close you can just make out the breather going from the oil filler to the rocker cover as apposed to going to where the copper pipe is.
This is what the original rocker cover and breather pipe setup should be
Now i understand the current engine came from a MK1 estate but i cant seem to get the diagrams from Service.Citroen for what i have in the engine bay (site playing up :? ).
I am assuming that what has been done is the air ducting etc from the original engine has been used and as this rocker cover has a breather outlet it has been plumbed in directly to the oil filler breather.
Can anyone shed some light on how to correct this without having to change the rocker cover/oil filler and associated pipes :)
Im not going to be keeping the car as stated in the original Thread just want to get it "right"
Cheers
Colin
Xaccers
x 186
Unread post by Xaccers »
Colin, pipe 5 is the one that goes from the cam cover to the filler housing down low on the back.
What's been disconnected and replaced with a copper pipe (no idea why) is item 3 and pipe 6 which connects to the upper spigot on the back of the oil filler housing.
So presuming that pipe 5 is still in place, you need pipe 6 and item 3.
DIY sphere tool
admiral51
(Donor 2026)
x 394
Hi Xac
Thats what i thought but having looked at the car briefly again tonight what is in place is pipe 6 which goes from the upper spigot on the oil filler housing to the cam cover (sorry i called it rocker cover :lol: )
This pipe is not the right one as its nearly folded over as it gets to the cam cover.
I couldnt see a pipe going to the lower part of the filler housing so assuming its not there :twisted: :twisted:
Could explain the oil on and around the injectors :)
Will need to have a closer look tomorrow and take some pics :)
Colin
Xaccers
x 186
Sounds like you need both pipes then.
DIY sphere tool
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
I think I made a comment about that breather missing!!
Surely your not intending buying a new one from the stealer?? Im sure I can find the one missing from your picture in the shed.. as for the cam cover to the oil filler one, that sits over the injectors thats a probleme for me, it goes brittle at the cam cover and splits...
Paul
A very sad...
1994 XM 2.1 d auto
Xaccers
x 186
I don't think they're that much from stealers, Cassy needed a new cam-filler pipe as hers split at the cam end as Paul mentioned.
DIY sphere tool
admiral51
(Donor 2026)
x 394
Paul you are correct,you did point out the breather was missing :)
I have now decided i am going to try and sort it out and then put it up for sale so making a list of what is needed :wink:
As for buying new
00001180F1 OIL VAPOR HOSE 9.31 GBP 10.94 GBP 10.94 GBP
0000118086 OIL VAPOR HOSE 5.03 GBP 5.91 GBP 5.91 GBP
Doesnt seem too bad,not exactly going to break the bank but will visit the scrappy saturday to see what else i can find :wink:
Sorry that this one makes yours not unique :)
Colin
Xaccers
x 186
Have you got the price/details of item 3?
DIY sphere tool
admiral51
(Donor 2026)
x 394
Xac wrote:Have you got the price/details of item 3?
Ouch :roll: :roll:
00001421A6 REGULATOR 29.05 GBP 34.13 GBP 34.13 GBP
Colin
citroenxm
Fallen Hero
x 70
DONT buy an Item 3 Admiral51
Im certain Ill have one of those with a free pipe to join it to the oil filler....
Paul
A very sad...
1994 XM 2.1 d auto
admiral51
(Donor 2026)
x 394
Im not sure if the HP pump was swapped or the original put back on so can anyone hazzard a guess as to which O ring i will need to stop this leak
I know they are only a couple of quid each but just for my own peace of mind :lol: :lol:
Cheers
Colin
Xaccers
x 186
2x number 5
One for where the pipe comes out and one for the hex blanking plug a bit further round.
DIY sphere tool
citroenxm
Fallen Hero
x 70
Jeee Xac
Your hot on the keys tonight
Paul
A very sad...
1994 XM 2.1 d auto
admiral51
(Donor 2026)
x 394
citroenxm wrote:DONT buy an Item 3 Admiral51
Paul
Cheers Paul :D :D
I will see what i can find/hide when i go to the scrappy on saturday but if i cant find anything ill take you up on your offer :) :)
Colin
Xaccers
x 186
citroenxm wrote:Jeee Xac
Paul
I have my uses :D
DIY sphere tool
