Eolys Rip Off
x 1939
woodywoodpecker wrote:i have a lexia but this is not used to remove it from the ecu you need a galletto cable to read your ecu file to laptop, Then run your file through software that removes all reffrences to the dpf and Eolys from the ecu. Once the modded ecu file is done simply write it back the ecu
Interesting. This may the source of a reference to reprogramming in another thread.
What it is doing, it appears, it setting all the options so that a FAP is no longer needed. Depending on the cost of the Galletto cable (which I've never heard but am about to Google!) and software it could be a more convenient way to change the options.
woodywoodpecker wrote:take the dpf and cat off exhaust and smash the guts out of both and refit to car.
I think I would take them off and replace with a length of pipe just in case I needed to refit them at some point. Even if they're never refitted the cat has scrap value which is worth reclaiming.
x 1939
Had a little look around and the problem for a lot of people may be that the car has to be EOBD II compatible. That means (for diesel cars) 2004 or later.
So OK for woodywoodpecker but cachaciero will be out of luck!
cachaciero
x 9
Unread post by cachaciero »
Paul-R wrote:Had a little look around and the problem for a lot of people may be that the car has to be EOBD II compatible. That means (for diesel cars) 2004 or later.
Well maybe, but if one is prepared to sacrifice the FAP none of this is necessary it only requires a few holes drilling through the fab the idea being to achieve the absolute minimum pressure drop consistent with the ECU still believing that it has a FAP or if an even lower back pressure is required and / or one doesn't want to scrap the filter and cat then as I said before a suitable resistor network in place of the dif pressure transducer which I have no doubt is a far cheaper solution than the cost of a Galletto cable.
Worth considering also that the FAP must act as an additional part of the silencing system I would have thought removing it completely and not replacing it with some kind of additional silencing would make the car noisier, not that that would worry some I know :-).
A replacement piece of pipe to go in place of the CAT and FAP sounds attractive but I guess that means finding bits and doing some welding, not that that in itself is a problem but I really have to many projects on the go at the moment. Now if the Galletto cable and software would read the gearbox ECU as well as the injection ECU that would be of interest...:-)
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
woodywoodpecker
Unread post by woodywoodpecker »
The car needs to be year 2000 for the cable to work, mine is a mk1 c5 2004 also done mk1 c5 2001 and peugeot 406 2.2 2001 with no problems.
citrokid
Unread post by citrokid »
woodywoodpecker
what software did you use with the galletto cable?
woodywoodpecker
citrokid wrote:woodywoodpecker
citrokid check your pm mate.
jimleshed
Unread post by jimleshed »
cachaciero
When I first got my lexia, the Eolys ECU was reported as a permanent error (I was trying to reset the EOLYS level).
After a couple of attempts to reset without luck I resorted to disconnecting the battery overnight. That cleared the permanent fault! (I think I had to reset it again afterwards, but that was back in the mists of time)
Since then all has worked fine.
Jim Le Shed
Citroen C5 2.2 HDI Exclusive
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
Citroen GS (lots of other Cars and Bikes too!!)
cachaciero
x 9
jimleshed wrote:cachaciero
Hi Jim
Yes disconnecting the battery was something I had thought about, your post has just pushed it up the agenda list :-)
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
cachaciero
x 9
Disconnecting the battery went higher up the list tthan expected, it died.....
New battery fitted sensor fault now cleared :-)
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
