Xantia running problems
KennyW
x 163
Unread post by KennyW »
Hi All,
I have been reading romie's thread with interest and I am wondering if he has possibly solved my problem of the rough idle.
In order to checking the stop solenoid,on my Bosch pump the ac3 model. I had to remove the armour. There is a securing/security pin which must be extracted before the armour comes off. This pin is inserted into a bevel in the max fuel screw.
What I noticed was the max fuel screw had moved slightly.
My question is would this have an effect on the rough idle as the car is running okay otherwise.
I hope the photo's make it clear.
Kenny
C3 1.4 petrol (SWMBO)
spider
x 77
Unread post by spider »
What kind of 'rough' is it ?
Does it seem to (almost) misfire or is the idle uneven (possibly moving slightly up and down)
In the case of the latter, its almost certainly a tiny air ingress causing it.
Andy.
MikeT
x 232
Unread post by MikeT »
That screw will either raise or lower the idle if turned enough, along with adding more/less fuel across the board. It shouldn't make the engine run rough (generally) but what's the idle at the moment and what was it before the screw was moved?
KennyW
x 163
Hi Andy and Mike,
I haven't turned the screw yet but was thinking of experimenting with it and I was only going to turn it slightly to see if it had an effect.
The idle is best described as vigorous engine shaking but steady no deviation.
Kenny
KennyW
x 163
Further to my question where will I find some info re How to tune up the pump insitu :?: :)
Kenny
