Being a bit of a photographer I tend to print quite a bit. The replacement inks for the HP were around £30 if memory serves, but again 5 A4 pages and they'd run out.
Likewise when my ex bought one of those 6x4 printers, because she thought it would be cheaper than getting them printed properly, and it worked out so expensive.
not car related but, cleaning print heads
Xaccers
- x 188
DIY sphere tool
DIY sphere tool
dnsey
- x 19
Kowalski
KP
- x 27
Rachels a teacher and goes through ink and paper like its going out of fashion so making it last important as she can go through a few 1000 in a month sometimes
poor trees i guess but it had to be wireless as well and the scanner and capacity of the tray makes life a lot easier as trays with 150sheets don't last long, i mean one night as well here, so having one that takes 500 makes life a lot easier
plus the carts have lasted a while and i always wait until the color doesn't match (ie one cart is out) as the gauges are usually way off i have found but will see how this new one goes as its lasted since before the summer which bodes well
THELABMAN
One tip to stop print heads drying out on the likes of Epsons with separate heads/tanks is to leave it on stand by and not switch it off... it also saves on the Epson at least ink as it misses out the process of the priming the heads each time you switch on.
The downside obviously is the cost of the electricity but it must be cheaper than the price of a new printer and ruined ink tanks for those who don't use the printer a lot.
Citroen C5 2.0 HDI SX Hatchback - 2002 (52)
Xantia Sensation 1.9TD (T) Mallard Green (Gone to the breakers)
- x 5673
