As above have a xantia HDI 110 the other day whilst driving i felt the rear becoming harder and bouncier.
When i parked up i noticed that the rear was set fully down as if i had lowered it.
I have noticed the stop light along with the brake style light stays light for a few seconds once started but does go out.
the rear wont rise at all not even when i try to do it with the lever.
The brakes and everthing else seem fine.
To my knowledge the suspension spheres have been done but not the one in the middle at the rear i think thats known as the anti sink.
Which i didnt notice when the car was switched off it would drop slightly at the rear.
Really need this sorted as its my daily runner.
Cheers
Stuart
Its dropped and wont come back up???
- x 1240
scoles
Onlinemyglaren
- x 5691
Not if you do it yourself
scoles
scoles
Little update been under the car and took pictures of what i found at the rear HC.
I think its maybe related to my problem.
Where could i get these parts to replace them fairly quickly?
It looks like the small metal arm has sheared off the clamp around the long bar under the car. i am guessing this has something to do with the height.
Cheers
Stuart
Cheers
Stuart
Onlinemyglaren
- x 5691
scoles
Onlinemyglaren
- x 5691
scoles
Onlinemyglaren
- x 5691
- x 8470
A ramp and patience Stuart.scoles wrote: Whats involved in resetting the height?
Not really difficult but a ramp or a pit is essential I find as it is vital that you can get under to adjust the clamp and this means having sufficient height available to ensure the car cannot crush you if it comes crashing down from high.
The job can be done on drive-up ramps with care and a lot of to-ing and fro-ing but it;s a right royal PITA to do it and frustrating.
Generally, a rough ball-park initial position for the clamp is when the 11mm bolt head is pointing more or less straight down as it roughly is in your picture.
In fact, if you mark the position of the old clamp and put the replacement on in precisely the same place you're unlikely to be far out although a little adjustment does make a good difference in height.
I'd do as much as possible, get it more or less at a drivable height and then take it to a place with a ramp or pit so the final adjustment can be done.
scoles
Thanks for that Jim, some good info there. I am understanding the linkage setup now a bit better.CitroJim wrote:A ramp and patience Stuart.scoles wrote: Whats involved in resetting the height?
I will source a new one from the stealers i imagine and try and remove the HC unit to free it off and lubricate it up before fitting the new clamp.
seems pointless putting the new clamp on to have it break due to a seized HC unit.
Stuart
scoles
well becuase of working all hours and being at night school i am finding it hard to get the time to get to the dealers to order the part i need.
Because its daily runner i am looking for a solution to temp fix it for the following week.
Can the HC unit be manually adjusted not that the automatic adjuster has broken off. ie set it to a height other than on the bump stops so i can get the car home?
Stuart
Stuart
- x 8470
Not really Stuart,
Even if you managed to get it to rise on the manual height lever you'd find that it will drift either to full high or right down low.
If the journey is short and smooth, it is just permissible to drive it very slowly home but I mean slowly and be very cautious over any speed humps or rough territory you may encounter. It will be incredibly bumpy.
Can you not ring a local dealer and ask him to get the part in for you and then quickly pop in to get it when he advises it's in stock? Our local dealer is very good like that.
