Xantia IR Fob Blade replacement
StevieM
Unread post by StevieM »
Folks,
Just ordered replacement IR, 2 button fob from ebay for my '95 Xantia.
Scoured web....seems that car actually learns fob code if ignition on/main fob button depressed with fob close to receiver dome near rear-view mirror....will give it a go.
Question is...to replace the blade with mine, do I prise the blade rivets apart, or drill out using my drill press?
Many Tks, Steve
x 1459
Unread post by xantia_v6 »
Prise them apart.
If your old casing is good, then just swap the new PCB into it.
