cant really get hold of one was just going to plum it in directly briefly and see if that helps.
as for that photo do you mean that you want a photo to show you how much the pump is angled towards the engine or the rad? cause its pretty much dead upright
I Need Help Please Citroen Xantia 97, 1.9td
MikeT
- x 232
Sorry, please forget the photo request, I was just grasping at straws because this is a challenging problem that seems to have us all baffled without a Lexia session.
It would be a real risk to not use a fuel filter, even briefly as it only takes one small particle to ruin your day (if it hasn't already happened), though I believe others have got away with it.
I recently bought an inline filter off ebay for a few quid. It's not large enough to last as long but should flow enough for testing purposes.
morph_1904
morph_1904
MikeT
- x 232
morph_1904
thats a job for today or tomorrow as its quite a big task and i still need to use the car,
i did have to plumb in the fuel lines differently as one of the clear ones broke when i was poking around.
this meant that i had to plumb it in directly to the pump on the way home.
and no difference so i dont think it is the fuel filter now.
morph_1904
Onlinemyglaren
- x 5674
Check the map morph and PM the one(s) nearest to you/easiest to get to and arrange a session with them.
If you could get to the Stratford meet at the weekend there will almost certainly be at least one Lexia there - but confirm in advance so as not to be disappointed.
morph_1904
hey thats like centre north london right?
if so it is going to cost me an absolute fortune to get there and i dont think i would have enough time the way the damn thing is running. also not sure of its reliabilty on such a long run, will look into pming a local lexia owner and see if i can get any luck there.
