whats the proper name for this please?
falling-out-with-my-car
- x 25
I want to buy a new part at the auto factors the MOT man says it is a bottom ball joint the auto factors think it is a track rod, but it is not .
it is the ball joint on the end of the swing arm at the bottom close to the wheel on a citroen xantia estate, 1,8 injection petrol.
the proper and correct name will help me identify it for the motor factors.
many thanks in advance
- x 1240
addo
- Sara Watson's Stalker
- x 95
- x 8401
- x 94
- x 25
actually I was cheating and asking for a friend with an xantia, but I Will pm you his last eigtht digits tommorrow (Thursday) Thank you.
Nigel.
Nigel.
vince
- x 13
it should be listed as a lower ball joint. I know the one they mean, i ordered some for mine a few weeks back but then it didnt need them
The tie rod is commonly referred to as a rack end by MOT stations and garages alike.
- x 94
- x 25
Malcom,
PM sent with last eight digits. my friend conveys his thanks for your help.
he has a mk1 1.8i xantia estate, this ball joint has only lasted a year before failing, I reckon he has been jumping from pothole to pothole in his car, either that or there was defect in the ball joint, whatever the part number it will be gratefully recieved.
I know where it is and how to locate it and that a broken one can only really be detected with the wheel off the ground but there has been confusion at really good auto factors over the proper name before.
thanks again.
regards Nigel.
thanks again.
regards Nigel.
- x 94
i know what you mean about confusion at motor factors, as they seem to change all the old part names, but citroen also name components with names that dont seem to have any barring on the actual part,
the price and part No. against that chassis/VIN No. is
0000364071 BALL JOINT SUSP 40.63 GBP 47.74 GBP 47.74 GBP
regards macolm
regards macolm
- x 25
Thanks Malcom I shall pass that on.
jesus no wonder no one with any sense buys parts from citroen main stealers. this part costs less than a tenner from the auto factors and citroen are adding more than a hundred % mark up, disgusting.
thanks again Malcom much appreciated.
regards Nigel.
regards Nigel.
- x 94
- x 25
probably made in sussex??
Nah i have seen auto factors pulling up to the citroen garage forcourt they use the same suppliers.
- x 94
try buying a MOTORQUIP swivle joint if you have a factors near by that are agents, as this brand is a susidury of Peugeot and are made to a good standard,
what you do find is an aufull lot of the stuff sold by the likes of ECP/GSF is sub standerd, im not saying all the parts they supply are as they do also sell some quite good parts,
regards malcolm
regards malcolm
